CRX Bogging problems
Old Apr 10, 2005 | 04:47 PM
jdmazm's Avatar
Default CRX Bogging problems
Ok, here is the problem, I turn the car on and the check engine light comes on after 5 seconds. I drive the car around and it drives normally, after about 3-4 minutes it starts to bog like crazy after 2500-3000 rpm, i can't get past 3200. And if i drive it for a while it will shut off. Can this be the result of a bad O2 sensor? I haven't checked for ECU codes yet. Please help me, I appreciate it guys!
Old Apr 10, 2005 | 04:52 PM
EJ2-Fluffy's Avatar
Default Re: CRX Bogging problems (jdmazm)
we cant do much if you can't check the ECU codes.
Sounds like your in limp mode (prevents the engine from running hard)
-Jon
Old Apr 10, 2005 | 04:59 PM
snakeboarder's Avatar
Mine did this when the distributor took a dump. I would check the code and distributor, might have jumped a tooth on the timing too. Just a few things to check.
Old Apr 24, 2005 | 04:35 PM
jdmazm's Avatar
Default Re: (snakeboarder)
yeah the 2 plugs were shot, i replaced the connectors and its all G.. i dint think it would throw me all of these codes.. runs a lot better than it did before my dizzy was bad. everyone go change your dizzys you get 100120949 hp.
Stephen122193
Jan 2, 2012 02:45 PM
88crxjordan
Feb 17, 2010 06:45 AM
civhatch90
27
Nov 29, 2006 09:05 AM
crx_soldier
May 2, 2005 01:16 PM
GuyInASpeedo
14
Sep 24, 2003 07:34 AM
