wheres the themostat on a 93 accorrd
There are two hoses for coolant to and from the radiator. The top one flows to the radiator, and the bottom one flows from the radiator to the back of the engine. The thermostat is in the part that the bottom radiator hose connects to. I believe there are two bolts that hold it to the head. If you need more help, just let me know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AmonDin »</TD></TR><TR><TD CLASS="quote">There are two hoses for coolant to and from the radiator. The top one flows to the radiator, and the bottom one flows from the radiator to the back of the engine. The thermostat is in the part that the bottom radiator hose connects to. I believe there are two bolts that hold it to the head. If you need more help, just let me know.</TD></TR></TABLE>
you are correct ... the best way is to just remove the hose and then use a 10mm socket to remove the 2 10mm bolts when you install the new thermostat remember that it has a up position so if you dont put it right they will leak
ILcrxsi1
Mar 29, 2007 03:14 PM
rewerbcrx
Dec 25, 2006 08:42 PM
icedlee
May 7, 2005 02:14 PM
