Help! Problem with 2002 Accord EX
Guest
Posts: n/a
Ok my digital clock doesn't come up at night, and on top of that its missing lines where some numbers are, for example if it was 8:30 it would read like l:30, well you get the jist, can anyone help me out.. thanks in advance
Pop the clock out by gently prying at the bottom with a smallish flathead screwdriver. Very gently if you have the woodgrain dash because those are easy to crack. Make sure it's plugged in tight. There is a little bulb in the back that is easily replaced. But it also sounds like the clock may be failing so you might check out a local boneyards for a used clock. I don't remember exact cost but I think they are rediculously expensive new.
JDM_Mugen_CD6
Oct 2, 2016 12:35 PM
rdmartyr7
Jul 25, 2009 01:13 PM
