LS dizzy for B16a1 engine??
Old Apr 10, 2005 | 02:02 PM
rediculous's Avatar
Default LS dizzy for B16a1 engine??
So i know that a LS obd0 distributor will work for a B16a1 OBD0 distributor but with mod (cut leg by vtec sol). Does anyone have pictures of the LS dizzy on a B16 engine (w/ leg cut off)? I want to see and know how much i need to cut off, also to find out if i can get two bolts to fit with one leg cut off.
I heard that a CRX/ civic Si 88-91 dizzy will work too (w/ leg cut off), would it be the same as a LS dizzy OR be bad for the car (temp use only)?
TIA
Old Apr 10, 2005 | 02:05 PM
doublethink's Avatar
Default Re: LS dizzy for B16a1 engine?? (rediculous)
i know you can use a 88-91 integra with a leg cut off.
is the LS dizzy you have pre-obd ???
Old Apr 10, 2005 | 02:15 PM
rediculous's Avatar
Default Re: LS dizzy for B16a1 engine?? (doublethink)
i havent got the LS dizzy yet, just want to know what i need to do and see some pictures of what's involved.
I was thinking 90-91 LS dizzy, since they are obd 0 (like my b16a1 obd0).
Correct me if im wrong
Old Apr 10, 2005 | 02:46 PM
Magick211's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">i know you can use a 88-91 integra with a leg cut off.
is the LS dizzy you have pre-obd ???</TD></TR></TABLE>
wrong you can use 90-91 integra with leg cut off
Old Apr 10, 2005 | 03:59 PM
rediculous's Avatar
anyone got pictures of thier LS distributor (leg cut off) on a b16a1 engine?
Old Apr 10, 2005 | 10:50 PM
rediculous's Avatar
anyone
Old Apr 11, 2005 | 12:00 AM
Redline130's Avatar
Just cut the leg as close to the distributor casing as possible.
Old Apr 11, 2005 | 12:40 AM
rediculous's Avatar
Default Re: LS dizzy for B16a1 engine?? (Redline130)
would it fit two bolt then for the LS distributor??
Im just worried that it would only fit one bolt (the top bolt).
Would the second bolt (closes to the firewall) bolt in too?
thnx all
Old Apr 11, 2005 | 01:52 AM
limpy's Avatar
i have one that came off my b16... pm me if interested. like $125 shipped.
Old Apr 11, 2005 | 02:18 AM
Magick211's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rediculous &raquo;</TD></TR><TR><TD CLASS="quote">would it fit two bolt then for the LS distributor??
thnx all </TD></TR></TABLE>
two bolts will work. dont really mattery wicnh ones they are anyway just know that two will work
Old Apr 11, 2005 | 03:08 AM
Grand's Avatar
ya 90-91 ls dizzy will work with one ear cut off but be forewarned sometimes but not all times you end up with a small oil leak
Old Apr 11, 2005 | 09:49 AM
rediculous's Avatar
Default Re:
Curious, what's white plug and gray plug??
White = OBD 0
Gray = obd1
Old Apr 11, 2005 | 10:10 AM
Default Re: Re: (rediculous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rediculous &raquo;</TD></TR><TR><TD CLASS="quote">Curious, what's white plug and gray plug??
White = OBD 0
Gray = obd1
????</TD></TR></TABLE>
yea, you just want to avoid having to rewire anything, cause thats un-needed and annoying.
if you really need a dizzy, distributor king has the exact obd0 dizzy for the b16a brand new, but its not exactly cheap.
just figured id throw that one out there. they also sponser this forum.
Old Apr 11, 2005 | 07:07 PM
pr0honda's Avatar
Default Re: Re: (doublethink)
obd0 distributor king distributors are on ebay for 149.99 dont cut a leg off your timing will be way off......
shawn
Old Apr 11, 2005 | 07:46 PM
tur3oDC4's Avatar
Default Re: Re: (pr0honda)
cut the leg- use the 90ls. the d16 dizzy wont work
Old Apr 11, 2005 | 08:09 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Re: (whitepoweredlsvtec)
A d16a6 distributor will work on a B16a1...
I put one on a friends car just recently { for the time being...}
Cut off the front leg,and it will bolt up/start/run;
but to get the timing right
you have to do some cutting/grinding...
I hated to "butcher" a good distributor,
but it was to help out a friend..
Old Apr 11, 2005 | 09:44 PM
rediculous's Avatar
Default Re:
I got a B16a dizzy for $180 cnd used and now the engine is boggin (misfire). Is this caused by the coil inside the distributor?
Old Apr 12, 2005 | 04:27 PM
rediculous's Avatar
anyone?? the idle is now fluctuating and i feel lost in power, could this be the new distributor??
Old Apr 12, 2005 | 06:53 PM
Redline130's Avatar
Did you set the timing after you installed the distributor?
Old Apr 13, 2005 | 09:31 AM
rediculous's Avatar
Default Re: Re: (Redline130)
yea, the timing has been set. I'm thinking it could be the vacum line (idle from 1k rpm to 200rpm).
I'll check it out.
THNX
b16a27
Jan 20, 2006 11:46 AM
Big_S
Sep 7, 2004 08:17 PM
