Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Ingalls Camber Kits Blow Out Sale Check It Out!
Old Apr 10, 2005 | 10:18 AM
UltraRev's Avatar
Default Ingalls Camber Kits Blow Out Sale Check It Out!
The worlds best designed an engineered camber kits. Ingalls is not just
another me-too player, they are the originator. Many other companies have
attempted to copy their kits but the attention to detail has been lost. Ingalls
kits are almost identical in weight to the OE pieces, with strength that surpasses
them. All Kits are sold in pairs Thus, each camber kit comes with the hardware
necessary to complete both sides of the car on either the front or rear end.
The Stiffy Engine Torque Damper:
93000 2002-05 Acura RSX (except the 05 type S) $149.99
http://www.ultrarev.com/ecart/shopexd.asp?id=48396
93020 1996-00 Honda Civic $149.99
http://www.ultrarev.com/ecart/shopexd.asp?id=48397
93021 1992-95 Honda Civic $149.99
http://www.ultrarev.com/ecart/shopexd.asp?id=48398
93021 1994-97 Honda Del Sol (with B16 Engine) $149.99
93022 2002-05 Honda Civic SI $179.99
http://www.ultrarev.com/ecart/shopexd.asp?id=55191
**All Ingalls Camber Kits are Priced for Pair**
35710 (rubber bushings) $104.48
http://www.ultrarev.com/ecart/shopexd.asp?id=1140
35700 (polyurethane bushings) $96.53
http://www.ultrarev.com/ecart/shopexd.asp?id=1139
35660 (brass bushings, not recommended for street use) $173.55
http://www.ultrarev.com/ecart/shopexd.asp?id=1148
Acura/Honda Front Adjustable Camber Kit
Adjustment Range
-3/4° to 1°
Vehicle Applications
Acura 2.2 CL 1996-97
Acura 2.3 CL 1998-99
Acura 2.5 TL 1995-98
Acura 3.0 CL 1996-99
Acura 3.2 TL 1996-98
Acura 3.5 RL 1999-02
Acura 3.5 RL 2003-04
Acura Integra 1990-01
Acura Vigor 1992-94
Honda Accord 1990-97
Honda Accord Wagon 1990-93
Honda Accord Wagon 1994-96
Honda Accord Wagon 1997
Honda Civic 1988-91
Honda Civic 1992-95
Honda CRX 1988-92
Honda Del Sol 1993-97
Honda Odyssey 1995-98
Honda Prelude 1992-96 Front
Honda Prelude 1992-96 Rear
Honda Prelude non-SH model 1997-02
Honda Prelude SH model 1997-02
Isuzu Oasis 1996-99
Part # 35590 $149.32
http://www.ultrarev.com/ecart/shopexd.asp?id=37882
Description Acura/Honda Front Adjustable Ball Joint
Vehicle Applications Acura 2.2 CL 1996-97
Acura 3.2 CL 2001-04
Acura 3.2 TL 1999-02
Acura 3.2 TL 2003-04
Acura TSX 2004
Honda Accord 1998-02
Honda Accord 2003-04
Honda Civic 1988-91
Honda CRX 1988-92
Adjustment Range -1 1/2° to +1 1/2°
Part #
35720 (polyurethane bushings) $113.39
http://www.ultrarev.com/ecart/shopexd.asp?id=1143
35730 (rubber bushings) $113.39
http://www.ultrarev.com/ecart/shopexd.asp?id=1146
35670 (brass bushings, not recommended for street use) $172.15
http://www.ultrarev.com/ecart/shopexd.asp?id=1149
Description
Acura Vigor 1992-94
Honda Civic 1988-91
Honda Civic 1992-95
Honda CRX 1988-92
Isuzu Oasis 1996-99
Adjustment Range
+1.25° to 3°
Part #
38811/38812 Polyurethane bushings, left/right side of vehicle only. $170.99
http://www.ultrarev.com/ecart/shopexd.asp?id=1573
38831/38832 Rubber bushings, left/Right side of vehicle only. $170.99
http://www.ultrarev.com/ecart/shopexd.asp?id=1153
Description
Adjustable Rear Toe Link
Acura Vigor 1992-94
Adjustment Range
-2° to +3°
Part #
38940 $19.99
Description
Rear Camber Adjuster
1990-97 Honda Accord
1992-94 Acura Vigor
1997 Acura 2.2 CL
1995-98 Acura 2.5 TL
1998-99 Acura 2.3 CL
1997-99 Acura 3.0 CL
1996-98 Acura 3.2 TL
1996-99 Acura 3.5 RL
Adjustment Range
up to +3/4°
http://www.ultrarev.com/ecart/shopexd.asp?id=1155
Part # 39207/39208 Left/Right Side with a ball joint $257.43
Description Adjustable Control Arm
Vehicle Applications Acura 3.2 CL 2001-03
Acura 3.2 TL 2003
Adjustment Range +1° to +4°
http://www.ultrarev.com/ecart/shopexd.asp?id=55370
Part #
38720 (polyurethane bushings) $143.99
Description
Adjustable Rear Camber Link
Adjustment Range
-1.5° to 3°
http://www.ultrarev.com/ecart/shopexd.asp?id=1249
Part # 39203/39204 Left/Right Side with a ball joint $205.99
http://www.ultrarev.com/ecart/shopexd.asp?id=51459
Acura 3.2 TL 2003
Adjustment Range -2° to +1-3/4°
Part #
35570 $159.99
Description
Acura Legend 1991-96
Adjustment Range
+1-3/4° to +4-1/4°
http://www.ultrarev.com/ecart/shopexd.asp?id=1248
Part #
35500 $119.99
Description
Honda Front Camber Adjusting Kit
1986-89 Honda Accord
Adjustment Range
+1-1/2° to +3/4°
http://www.ultrarev.com/ecart/shopexd.asp?id=1385
Part #
38600 (polyurethane bushings) $91.99
http://www.ultrarev.com/ecart/shopexd.asp?id=1386
38620 (rubber bushings) $91.99
http://www.ultrarev.com/ecart/shopexd.asp?id=1387
Description
Adjustment Range
-2° to +3°
Part # 35594 $159
http://www.ultrarev.com/ecart/shopexd.asp?id=38334
Description Honda Front Adjustable Ball Joint
Vehicle Applications Honda Accord 1990-97
Part # 35591 $149.99
http://www.ultrarev.com/ecart/shopexd.asp?id=38307
Acura TSX 2004
Honda Civic 1988-91
Honda CRX 1988-92
Adjustment Range +1 1/2° to +3°
Part #
38725 (rubber bushings) $139.99
http://www.ultrarev.com/ecart/shopexd.asp?id=51457
Description
2003-04 Honda Accord Camber
2004-2005 Acura TSX
Adjustment Range
-1.5° to 3°
Part #
38900 (polyurethane bushings) $93.86
http://www.ultrarev.com/ecart/shopexd.asp?id=1114
38920 (rubber bushings) $96.53
http://www.ultrarev.com/ecart/shopexd.asp?id=1115
Description
Honda Civic 1988-00
Honda CRV 1997-01
Honda CRX 1988-92
Adjustment Range
-2° to +3°
Part #
38930 $14.54
http://www.ultrarev.com/ecart/shopexd.asp?id=1116
Description
Honda Civic 1988-00
Honda CRX 1988-92
Adjustment Range
up to +3/4°
Part #
39101/39102 Rubber bushings, with ball joint, Left/Right $203.84
http://www.ultrarev.com/ecart/shopexd.asp?id=1586
39104/39105 Polyurethane bushings, with ball joint, Left/Right $203.82
http://www.ultrarev.com/ecart/shopexd.asp?id=1588
Description
Adjustable Control Arm with ball joint
1996-2000 Honda Civic
Adjustment Range
-1° to +4°
Part #
35420 $19.99
http://www.ultrarev.com/ecart/shopexd.asp?id=1126
Description
MacPherson Strut Camber Adjuster
Vehicles with 14mm OE strut to spindle mounting bolts
See specific applications for full listing.
Adjustment Range
± 1°
Part #
81260 $35.99
http://www.ultrarev.com/ecart/shopexd.asp?id=2168
Description
Adjustment Range
up to ± 2°
Part #
38950 (polyurethane bushings) $108.60
http://www.ultrarev.com/ecart/shopexd.asp?id=1127
38970 (rubber bushings) $111.20
http://www.ultrarev.com/ecart/shopexd.asp?id=1128
Description
Acura RSX 2002-04
Honda Civic 2001-02
Honda Civic SI 2001-04
Adjustment Range
-4° to +7°
Part #
35440 $19.99
http://www.ultrarev.com/ecart/shopexd.asp?id=1124
Description
Vehicles with 16mm OE strut to spindle mounting bolts
Adjustment Range
± 1°
Part #
81280 $36.31
http://www.ultrarev.com/ecart/shopexd.asp?id=1730
Description
Adjustment Range
up to ± 2°
Part #
35640 $58.99
http://www.ultrarev.com/ecart/shopexd.asp?id=1742
Description
Honda Front Adjuster
1983-87 Honda Prelude Front
Adjustment Range
-1° to +3°
Part #
35650 $58.99
Front: http://www.ultrarev.com/ecart/shopexd.asp?id=1746
Rear: http://www.ultrarev.com/ecart/shopexd.asp?id=1748
Description
1988-91 Honda Prelude Front & Rear
Adjustment Range
-1° to +3°
Part # 35599 $188.67
http://www.ultrarev.com/ecart/shopexd.asp?id=38401
Description Acura/Honda Adjustable Ball Joint
Vehicle Applications Acura Vigor 1992-94
Honda Prelude 1992-96 (front)
Honda Prelude 1992-96 (rear)
Part # 35598 $155.54
http://www.ultrarev.com/ecart/shopexd.asp?id=38394
Part # 35592 $149.32
http://www.ultrarev.com/ecart/shopexd.asp?id=37916
Vehicle Applications Acura 3.2 TL 1996-98
Honda Civic 1992-95
Honda Civic 1996-00
Part # 35593 $188.67
http://www.ultrarev.com/ecart/shopexd.asp?id=38327
Honda Civic 1992-95
Honda Civic 1996-00
Part #
35580 $180.99
http://www.ultrarev.com/ecart/shopexd.asp?id=1774
Description
1997-2002 Honda Preludes
Part # 35596 $188.67
http://www.ultrarev.com/ecart/shopexd.asp?id=55381
Description Honda Adjustable Ball Joint
Vehicle Applications Honda Prelude SH model 1997-02
Part # 35597
http://www.ultrarev.com/ecart/shopexd.asp?id=55382
CALL US FOR NOT LISTED APPLICATIONS
Old Apr 11, 2005 | 05:38 AM
UltraRev's Avatar
Default Re: Ingalls Camber Kits Blow Out Sale Check It Out! (UltraRev)
This is a really good deal jump on it!
Old Apr 11, 2005 | 03:19 PM
UltraRev's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltraRev &raquo;</TD></TR><TR><TD CLASS="quote">This is a really good deal jump on it! </TD></TR></TABLE>
Old Apr 12, 2005 | 06:42 AM
UltraRev's Avatar
Old Apr 12, 2005 | 08:47 AM
b16ada6's Avatar
http://www.ultrarev.com/ecart/shopexd.asp?id=1111 $113
hey man i need more info about this kit. First of all i need something that is ganna cover a 2"-3" drop. i know you have it for $113 but i was wondering if this comes with the hardware for both front wheels? or am i ganna have to buy something else on top of that kit? i'm ready to buy so hit me up asap.
*edit
one more thing, how long does ground shipping usually take?
Old Apr 12, 2005 | 09:33 AM
UltraRev's Avatar
Default Re: Ingalls Camber Kits Blow Out Sale Check It Out! (92MilanoTeggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92MilanoTeggy &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ultrarev.com/ecart/shopexd.asp?id=1111 $113
*edit
Comes with everything for the front both wheels meaning 2 kits pair. You wont need anything else.
Old Apr 13, 2005 | 07:28 AM
UltraRev's Avatar
Old Apr 13, 2005 | 11:22 AM
UltraRev's Avatar
in stock ready to ship!
Old Apr 14, 2005 | 06:06 AM
UltraRev's Avatar
*edit
</TD></TR></TABLE> you still need it?
Old Apr 14, 2005 | 07:22 AM
garaged_Si's Avatar
Can i get a price quote for Rear Camber Kits 1999 Civic Si with H&R race and AGX. shipped to CA 91307? Thanks.
Old Apr 14, 2005 | 12:27 PM
UltraRev's Avatar
Default Re: (garaged_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garaged_Si &raquo;</TD></TR><TR><TD CLASS="quote">Can i get a price quote for Rear Camber Kits 1999 Civic Si with H&R race and AGX. shipped to CA 91307? Thanks.</TD></TR></TABLE> pm sent, prices were in my first post you have to decide if you want rubber or polyurethane.
Shipping is calculated on our website by address before check out.
Thanks!
Old Apr 15, 2005 | 06:28 AM
UltraRev's Avatar
Default Re: (UltraRev)
Old Apr 15, 2005 | 10:59 AM
b16ada6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltraRev &raquo;</TD></TR><TR><TD CLASS="quote"> you still need it? </TD></TR></TABLE>
yes i'm waiting till monday thought. so how much is the total ganna be with shipping? and how long is shipping ganna take aproximatelly?
Old Apr 15, 2005 | 01:15 PM
UltraRev's Avatar
yes i'm waiting till monday thought. so how much is the total ganna be with shipping? and how long is shipping ganna take aproximatelly? </TD></TR></TABLE> shipping is calculated on our website before check out, ships out same day takes 2-5 days for delivery,
Old Apr 17, 2005 | 10:58 AM
UltraRev's Avatar
shipping rates are much lower now usually $5-7
These kits are going fast
Old Apr 19, 2005 | 05:33 AM
UltraRev's Avatar
pms replied.
Old Apr 20, 2005 | 10:03 AM
UltraRev's Avatar
pms replied.
Old Apr 22, 2005 | 10:27 AM
UltraRev's Avatar
Old Apr 22, 2005 | 05:37 PM
GAME OVER 2007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltraRev &raquo;</TD></TR><TR><TD CLASS="quote">This is a really good deal jump on it! </TD></TR></TABLE>i like the price
Old Apr 28, 2005 | 06:37 AM
UltraRev's Avatar
Default Re: Ingalls Camber Kits Blow Out Sale Check It Out! (Aznxgsrxguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aznxgsrxguy &raquo;</TD></TR><TR><TD CLASS="quote">i like the price
Old Apr 29, 2005 | 05:25 AM
UltraRev's Avatar
Old May 1, 2005 | 10:00 AM
UltraRev's Avatar
Old May 3, 2005 | 06:27 AM
UltraRev's Avatar
Old May 4, 2005 | 08:38 AM
UltraRev's Avatar
Old May 5, 2005 | 06:04 AM
UltraRev's Avatar
Thanks for all the orders.
