no compression at 900 miles
i have a 3rd gen with a built b20 new rods pistons etc... i broke it in for 800 miles and was pulling 18 inches of vaccum on decel. so i started boosting 7 pounds. 3 days later 90psi compression on all four cylinders. wasnt running lean 550cc injectors & FMU. what could have caused this ???
How do you know you were not running lean? Did you pull your AF's via wideband 02? You do realize that by running 7psi on a stock ECU you were running ZERO degree's of timing retard. My guess is the advanced timing fried your pistons, egged your cylinder walls, or blew your headgasket.
FMU = garbage
FMU = garbage
harryg
Jun 20, 2002 07:56 PM
