How to Remove Parking Lights 4th Gen
I Looked everywher but cant find how to replace my parking led....I dont wanna try something and break it...is screw number 23 the only thing holding it ? any pointers/instructions on how to change bulb would be good.
btw will these bulbs fit ?
Yeah there is only one screw holding it in, but you have to either pull REALLY hard or use a screwdriver wrapped in cloth to wedge it out.
That should be the right bulb also.
From: united states of mexico and yes ladies i am, available
theis are better
heres some pics of them on my car
Modified by raylude at 3:52 AM 4/11/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude »</TD></TR><TR><TD CLASS="quote">theis are better
Modified by raylude at 3:52 AM 4/11/2005</TD></TR></TABLE>
Not really liking the blue, but if they have them in white i'd get them. Where'd you get yours?
Yah, you're gonna have to use a bit of force when taking the corner light out. Once you take that screw out, there's a little metal piece that kind of snaps into a plastic hole. The metal piece is cylindrical but it's also wedge shaped so wedges itself in there. When you take it out and put it in, it's almost like popping it in and out. Hope that isn't too confusing! haha
not blue its white their blue bulbs are BLUE!
http://www.superbrightleds.com
the corner lights on the headlights on the 4g was always a pita that thing just never seemed to want to come out and go back in :/ just a matter of wiggling till u can't wiggle no more...i hate japanese made cars sometimes they seem to make the most simple tasts a tad more difficult than they really should be
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecludeh22 »</TD></TR><TR><TD CLASS="quote">like some have said wiggle it out but you have to pull it horizontally forward for the metal peice that acts like a button </TD></TR></TABLE>
Yes, this is right on, you have to pull it straight out, almost pry it out! Pull it out towards the front of the car..you can't really angle it or pull it towards the side, but rather just straight towards the front. I'll try and find actual pics, as for the diagram, I don't believe it's in the diagram because it's built right into the housing.
sweeet thanks man...I found out what the diff bulbs do (Concave len converse the light beam in different directions)....so which one should i put ??
Which one is better, concave or convex ??
1.
2.
1.
2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludelvr »</TD></TR><TR><TD CLASS="quote">
Yes, this is right on, you have to pull it straight out, almost pry it out! Pull it out towards the front of the car..you can't really angle it or pull it towards the side, but rather just straight towards the front. I'll try and find actual pics, as for the diagram, I don't believe it's in the diagram because it's built right into the housing.</TD></TR></TABLE>
u found the pics man ?
once you remove the screw - you have to SLIDE the corner light towards the headlight(and a little bit out) to get it out. /__/ <-headlight |) <-- corner light
/__/|) <--full thing....(your driver side)
You have to slide the corner light to the left (towards the headlight) once the screw is removed.
luxcan01
May 3, 2004 11:52 AM
LudEcrous
Aug 26, 2003 09:47 PM
