Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
205/50/15 Azenis and 15x7 K-1s...
Old Jan 28, 2002 | 09:40 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default 205/50/15 Azenis and 15x7 K-1s...
will I have any problems mounting them? I was pretty sure it would fit since the Azenis are so damn wide, but I don't know for sure.
Old Jan 28, 2002 | 09:42 PM
Chris's Avatar
Default Re: 205/50/15 Azenis and 15x7 K-1s... (Ross)
205's fit on stock 6.5"ers. No problem
Should have gone 215 (if available?)
Old Jan 28, 2002 | 09:48 PM
Ross's Avatar
25 Year Member
Community Builder
Default Re: 205/50/15 Azenis and 15x7 K-1s... (Chris)
sure they fit on the stock 6.5ers, but on a 7" wide wheel?
Old Jan 28, 2002 | 10:46 PM
Reid's Avatar
Global Moderator
They should fit well.
Old Jan 28, 2002 | 11:05 PM
Ross's Avatar
25 Year Member
Community Builder
Default Re: 205/50/15 Azenis and 15x7 K-1s... (Reid)
thanks Reid...BTW you're at 1013 posts...my R is #1013. Must be the right answer then...
Old Jan 29, 2002 | 04:11 AM
Neo's Avatar
Neo
Ross, could you be talking about two issues of fitment here: first, if the tire will be on the rim; second, if the tire will/will not rub the fender and/or LCA once on the car? Given that Azenis run wider than most 205s, your question is a good one. I don't see any reason why they would not fit on the 15x7 Kosei's, but whether or not it'll rub is something I'm very interested in finding out, too. This same wheel/tire combo is what I'm hoping to do for my Geezer some time this year. Anyone got experience with this second fitment issue?
Old Jan 29, 2002 | 04:15 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Default Re: 205/50/15 Azenis and 15x7 K-1s... (Neo)
Depending on what offset you get, there should be no rubbing issue. I can fit a 225 Hoosier on a 38mm offset wheel under my car with only the tiniest bit of rubbing on the rear trailing arm. A 2 or 3 mm spacer would cure it if I cared enough to get one. I did have to roll the rear fenders though.
Hoosiers running wide like they do, I am sure we are talking apples to apples here.
HTH.
Old Jan 29, 2002 | 04:18 AM
Neo's Avatar
Neo
Default Re: 205/50/15 Azenis and 15x7 K-1s... (madhatter)
Thanks, Chris. That does help. To clarify, tho, your Enkei wheels are 15x7, no?
Old Jan 29, 2002 | 04:48 AM
CivicSiRacer's Avatar
Default Re: 205/50/15 Azenis and 15x7 K-1s... (George Knighton)
The 205/50x15" Azenis I just had mounted on 15x7" Kosei K1 on Wednesday - they fit perfect and are a bit wider than other 205s.
The only problem you want to look out for is the offset. 38mm and 45mm are available for that size - and on my car I went with a 45mm cause 38s would rub. But the 45mm rub a little on the wheel and the rear upper control arm. I bought spacers (2mm) which should fix that.
Old Jan 29, 2002 | 05:02 AM
madhatter's Avatar
Yep.
Old Jan 29, 2002 | 05:18 AM
ZygSpeed's Avatar
Sorry, but I was under the impression that the stock ITR wheels were/are 15 X 6 (not 6.5)?
Old Jan 29, 2002 | 06:42 AM
I'm am dropped 1" with Eibach Prokit. They rub on the inside rear wheel when making hard transitions. I assume if I was lower I wouldn't have this problem.
Old Jan 29, 2002 | 08:46 AM
GSpeedR's Avatar
Default Re: 205/50/15 Azenis and 15x7 K-1s... (CivicSiRacer)
So, the 205/50 15 Azenis probably would be too wide for 95 GSR wheels (which are 6" wide, I believe). Has anyone fit 205 Azenis on a GSR wheel?
I hate it when you have to answer your own question.
[Modified by GSpeedR, 9:47 AM 1/29/2002]
Old Jan 29, 2002 | 08:51 AM
Conechaser's Avatar
Default Re: 205/50/15 Azenis and 15x7 K-1s... (GSpeedR)
I have 205/15/50 on a 15x5.5 Accrod rim, took the place 2hrs and lots of cussing to get them mounted according to my little brother, he works there. So they should fit fine on a GSR rim, which is 15x6.5.
Old Jan 29, 2002 | 08:57 AM
Chris's Avatar
Default Re: 205/50/15 Azenis and 15x7 K-1s... (zygspeed)
If they are...my bad.
Old Jan 29, 2002 | 04:04 PM
joeg26er's Avatar
Where can I get Azenis online?
No one in my area has them- even Ecsta supra 712's are hard to come by.
Thanks
Old Jan 29, 2002 | 06:03 PM
GSpeedR's Avatar
Default Re: 205/50/15 Azenis and 15x7 K-1s... (94Accord)
Are they 6.5"? Cool. Thanks.
Old Jan 29, 2002 | 06:08 PM
Xerxes's Avatar
New User
Default Re: 205/50/15 Azenis and 15x7 K-1s... (joeg26er)
Thanks
http://www.falkentires.com ( http://www.vulcantire.com )
onlyneed4
Jul 27, 2005 04:56 PM
Racermech
Feb 20, 2005 02:02 PM
corpsickle
Jun 9, 2004 03:47 PM
jg
Sep 23, 2003 03:40 AM
cleanASScoupe
Jan 26, 2003 08:10 PM
