wireharness for std hatch
hi i have a b18a obd1 and was going to buy an 91 obd 0 wire harness and i was just wondering if i could use it in my std hatchback or is there some more wiring since its dpfi and is there any different sensors plugs the the harness would not fit into thanks for any ones help
you're gonna need to run your car for mpfi.
you'll also need axles, shift linkage, mounts.
use a cable trans or you'll have to pay for the cable-hydro conversion kit.
edit: rereading what you said, I may have been misunderstanding your question. If what I said makes sense, cool. If not, never mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efstd »</TD></TR><TR><TD CLASS="quote">hi i have a b18a obd1 and was going to buy an 91 obd 0 wire harness and i was just wondering if i could use it in my std hatchback or is there some more wiring since its dpfi and is there any different sensors plugs the the harness would not fit into thanks for any ones help</TD></TR></TABLE>
don't buy a 91 harness. Modify your std harness. Convert to mpfi, get a pre-obd to obd1 conversion harness, add three more wires for the o2 sensor and enjoy. Might want to pick up one of those distributor jumpers too. You'll also need a 4 wire o2 sensor from any 92-95 honda.
no because you cant run it. you can't just plug a mpfi engine harness into the std harness. if you want to run a mpfi harness, you have to change all the harnesses on the chassis.
im not trying to make my std engine mpfi ,you have to read what i wrote im doing a b18a swap and was wondering if i could us a 91 wireharess with out doing any major wiring
people on this site have to read before they post
he's saying that the integra harness will NOT plug into your car without extensive wiring, it is easier to modify the harness on your engine than to do that. so, therefore, convert your wiring to mpfi in prep for the b18.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efstd »</TD></TR><TR><TD CLASS="quote">it wouldnt be just easier to buy the integra harness? the integra is not dpfi just to clear that up</TD></TR></TABLE> no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efstd »</TD></TR><TR><TD CLASS="quote">im not trying to make my std engine mpfi ,you have to read what i wrote im doing a b18a swap and was wondering if i could us a 91 wireharess with out doing any major wiring</TD></TR></TABLE>
you will be doing major wiring if you use the 91 harness. You will be doing minor wiring if you use your 89 std harness. Keep it simple and just mod your 89 harness.
i think you're just not reading what im saying correctly. you're reading it and thinking what you want to think. but the thing is , the mpfi harness will NOT plug in without rewiring the WHOLE car. the much easier way is to convert the std harness to mpfi, or pay for a conversion harness from http://www.rywire.com
</TD></TR></TABLE>i think you're just not reading what im saying correctly. you're reading it and thinking what you want to think. but the thing is , the mpfi harness will NOT plug in without rewiring the WHOLE car. the much easier way is to convert the std harness to mpfi, or pay for a conversion harness from http://www.rywire.com
Eighty-Nyne
May 27, 2009 11:55 AM
kyle1jzsupra
Aug 29, 2008 02:57 PM
vtec25
May 7, 2007 06:56 PM
