Power door locks
I'm posting this for a friend. He has a 2004 Honda Accord Sedan DX. He wants to know if you can intall power door locks on it. Either Aftermarket or OEM. He has an alarm system that already unlocks the car when the alarm is disabled, but he wants the unlock/lock switch in the car.
If the car unlocks and locks with his alarm he already has power locks. He would probably be able to swap out his drivers door switches for a set out of a lx/ex and just figure out how to wire it or have the people that installed his alarm wire it.
I am researching how to add the locks myself... the problem with the factory power lock button is that it is connected to the rest of the power window switches so you would have to change all of that over. Did he use aftermarket actuators or the honda actuators?
Yeah, I was referring to swapping the whole panel switches and all. Of course it wouldn't be an easy direct swap as he would have to wire his most likely aftermarket PDL system into the stock switch but the whole panel should just swap out as far as putting the switch in goes.
Ehron
Audio / Security / Video
May 23, 2002 07:59 AM
