Bearing on top of the mainshaft
Old Apr 9, 2005 | 05:30 PM
lunarcry's Avatar
Default Bearing on top of the mainshaft
I just finished putting in a Quaife by myself. Wasn't too bad a task overall. Now I am concerned because the Large bearing on top of the Mainshaft comes off very easily! Its supposed to be a pressed on bearing. Should it come off so easily? Anyone ever see this before? by the way the transmission is an h23 m2s4.
Old Apr 10, 2005 | 06:04 AM
lunarcry's Avatar
Default Re: Bearing on top of the mainshaft (lunarcry)
Old Apr 10, 2005 | 10:14 AM
lunarcry's Avatar
damn, I guess nobody here has ever open an H23 transmission...
Old Apr 10, 2005 | 10:26 AM
PrecisionH23a's Avatar
Snap a picture of it to refresh my memory...
Old Apr 10, 2005 | 10:59 AM
LudeyKrus's Avatar
Default Re: Bearing on top of the mainshaft (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Snap a picture of it to refresh my memory...</TD></TR></TABLE>
You've torn into a tranny?!
:shudders:
You're a braver man than I.....
Original poster: You say it's not that bad of a job; don't you have to set a bunch of clearances? Or is it more of a "assemble it and make sure everything's still in spec" kind of thing?
Old Apr 10, 2005 | 11:06 AM
Default Re: Bearing on top of the mainshaft (LudeyKrus)
It's not as bad as people think... the quaife does not require shims so as long as you don't remove any gears from the main shafts you'll be ok.
Old Apr 10, 2005 | 11:26 AM
4.6LJeepXJ's Avatar
Did you press the bearing off to begin with... Bearings cant take being pressed on and of repeatedly or they tend to break. Best bet replace the bearing, saves you from having to replace it when it fails someday, not long from now, when your driving down the road.
Old Apr 10, 2005 | 11:41 AM
machine4321's Avatar
ok i just finished my h22 usdm and i notices that the main bearing was still in the housing...but in the book it shows to have it pressed off..what givs..it went back together but now 5th wont catch ..you have to hold it in gear ...
Old Apr 10, 2005 | 12:59 PM
lunarcry's Avatar
here are some pictures
what bother me more is that it appear that the bearing seem to be holding everything on place and without the bearing on place the gears are loose. should it be like that on the h23 transmission?
I got an h22 transmission apart too but the bearing is on it tight. is this one of the way the h23 differ from the h22 transmission?
Old Apr 10, 2005 | 01:13 PM
salvageland's Avatar
when I changed my tranny housing, I just pulled that pearing out, and replaced it with another one, didn't have to be pressed in. I think the manual say'd to use a bearing puller which all it does is pull out the bearing evenly. THerefore, I don't think the bearing is pressed in, just make sure u align that little metal peice with the bent part properly, and reassemble the tranny, here are some pics of mine, by the way another way u can assemble it is put the main bearing inside the housing where it's supposed to mount and mate the 2 housings together, makes it much easier this way
Old Apr 10, 2005 | 01:36 PM
LudeyKrus's Avatar
So do the gears and synchros have to be pressed on and off, or do they go on easily like the bearing?
Old Apr 10, 2005 | 01:46 PM
lunarcry's Avatar
Default Re: (LudeyKrus)
that's sort of what i want to know? I know that on the h22 they do is on the hems manual but on an h23, I don't know if the bearing and/or gears should be all press just like the h22.
Old Apr 10, 2005 | 02:39 PM
Eddiebx's Avatar
yes the bearing on top slides off easily no biggie
Old Apr 10, 2005 | 04:11 PM
lunarcry's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">yes the bearing on top slides off easily no biggie</TD></TR></TABLE>
what about the gears and the synchros? should they be press or can they be laid on the mainshaft just like that?
Old Apr 10, 2005 | 04:41 PM
Eddiebx's Avatar
all of them jsut fall apart, so becareful not to mix up the order, heh
Old Apr 10, 2005 | 05:03 PM
mgags7's Avatar
^^yeah have fun with that.....
you guys are brave, there are soo many little peices and **** in there.....
Old Apr 10, 2005 | 06:45 PM
LudeyKrus's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">^^yeah have fun with that.....
you guys are brave, there are soo many little peices and **** in there.....</TD></TR></TABLE>
There's plenty of little parts in a motor also.
It still gets me, though. I will tear into a motor no problem, but won't dare get into a tranny; it's a black box to me that does a job....if it breaks, I'll replace it.
Old Apr 10, 2005 | 07:35 PM
im gonna be honest ...its not hard ..i just got into my first tranny and i feel like a pro lol
it must have helped that every thing in side mine is screwed totally but i ffel comfortable in there after a few min
Old Apr 10, 2005 | 08:32 PM
lunarcry's Avatar
Default Re: (machine4321)
you guys are brave, there are soo many little pieces and **** in there.....</TD></TR></TABLE>
its not hard at all, its less complicated than the engine. its all about taking your time and paying attention to details. plus one can admire the ingenuity of how the Honda transmissions are build-very impressive
Old Apr 10, 2005 | 09:32 PM
accord387's Avatar
yea that bearing will come on and off easily. It was easier for me to ahve the bearing on the shaft so that the metal shim thingie below it didnt keep messing up. I was terrified to take apart a tranny (because fo the story gears will jsut fall apart blah blah blah), its not that big of a deal.
pentaq
Nov 16, 2004 03:10 PM
SUB-0 H23
Nov 3, 2004 07:52 AM
99spanishGT
Dec 28, 2003 11:19 AM
ludesleep
May 8, 2003 09:04 PM
Smurfylude
Jul 30, 2002 12:17 PM
