ls block, gsr head, what timing belt?
Old Apr 9, 2005 | 03:30 PM
B18 CYA's Avatar
Default ls block, gsr head, what timing belt?
what timing belt am i supposed to use on a b18a block with gsr head? a gsr timing belt or ls timing belt? Thanks
Old Apr 9, 2005 | 03:37 PM
4door-r's Avatar
Default Re: ls block, gsr head, what timing belt? (B18 CYA)
ls timing belt. since your water pump is ls then you use ls timing belt, the cam gear teeth on the gsr will fit the belt.
Old Apr 9, 2005 | 03:39 PM
GOLDBERG's Avatar
what water pump?
Old Apr 9, 2005 | 03:56 PM
B18 CYA's Avatar
type r oil pump and vtec water pump
Old Apr 9, 2005 | 05:19 PM
kadburry's Avatar
Default Re: (B18 CYA)
if you use a gsr water pump get the gsr timing belt
Old May 11, 2005 | 03:11 PM
civicswap's Avatar
Default Re: (kadburry)
you need a vtec belt
rick_rabies
Apr 1, 2009 12:59 PM
timm099
Dec 13, 2006 06:09 AM
jdmCivic925
Jan 25, 2006 08:37 PM
JdmH22Acorn
May 16, 2005 08:16 PM
BoOsTiN Dc2
Feb 7, 2004 02:32 AM
