Quick help: radiator removal on CRX for a b-series swap?
Got the d16 out. But it seemed tight, with the radiator in there...will i need to remove the radiator to install the b16? Thanks.
While you don't need to remove it, I removed mine so I wouldn't be able to damage it in any way during the installation process.
i ALWAYS remove radiators....
easily damaged, also easy to take out
spend 5 minutes and take it out, unless u dont like it!!
im using a dual core teg radiator, no room really for msitakes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h »</TD></TR><TR><TD CLASS="quote">You might as well pull it out. You have to drain it anyways. </TD></TR></TABLE>
yup, all you gotta do to take it out is remove 4 bolts and the 2 top mounts and unplug the fan.
