00 civic wont start (stumped)
-ok, car doesn't make any sound when i try to start it.
- all the ignition lights and radio work fine ( new battery)
- i checked the igniton fuse and starter fuse and other fuses under the dash, good
- checked starter relay under the steering coloumn dash panel, good
- check the starter, good
- check the grounds, good ( the only grounds that i can rmeber of are the tranny ground that would cause anything like this)
- fuel pump is kicking on, and getting good fuel pressure
- main relay near the glove box is clicking when i try to start the car
my car sat for about 10mths, after a clutch failure. i recently replace the clutch. everything is back together except the fact that the car wont start.
please help
please help
I thought the main relay was located way over on the left, above the hood-release lever.
Does the starter crank the engine? If not, then check whether the starter is getting a signal on it's small wire. If it's not, the next couple things to check depend on whether it's auto or manual tranny...
