y8 injectors
Old Apr 9, 2005 | 11:05 AM
mr. carpenter's Avatar
Default y8 injectors
i can use the y8 injectors with my pm6 ecu as long as i solder the wires together and eliminate the resistor box, correct?
Old Apr 9, 2005 | 01:43 PM
Redline130's Avatar
Default Re: y8 injectors (mr. carpenter)
That would be correct.
Old Apr 9, 2005 | 01:44 PM
eda6's Avatar
If you can find an obd1 block off plug, no soldering is required.
Old Apr 9, 2005 | 01:56 PM
Default Re: y8 injectors (eda6)
what i did was took the resistor box's plug, cut it and soldered those wire so if i ever, for some ungodly reason, need to put the non-obd injectors in, the plug will still be there. thanks guys.
eda6: i called that motor supplier on that d15b and told them they were idiots in not so few words and they came and got the d15b and brought me a z6. thanks for your help on that.
johnjw
Apr 30, 2012 02:00 AM
Wes90civic
Feb 22, 2004 07:25 AM
xmd
Sep 27, 2003 09:51 PM
photonjedi808
May 13, 2003 09:16 AM
vtecrx
11
Sep 14, 2002 08:19 AM
