HELP 1998 accord stuck in park
My mom has a 98 accord auto and she called me yesterday and said it wont shift out of park. I looked at it briefly but couldnt figure it out. Can somebody plese help me?
Thanks
Thanks
when the car is on, when you step on the brake panel do you hear the little tick sound?
anyway, try to stick the key in the shift lock thing and see if you can lossen it up, it's locked just next to the shifter
Is the brake pedal very stiff?
Take off the plastic covering around the shifter. There is an indentation in the front on of it where you can stick something like a screwdriver in there, and lift the covering off. Stick the key in the little slot, and push down. Change the gear, and you're done.
It is said that this only happens when there is something wrong with the car, and should be taken in for service. One of my main fuses blew a while ago, and the car refused to start, so I had to do this method.
Thanks guys, i got it out of park but the brake lights arent working. I tried to find the brake fuse but i couldnt find it. Any ideas on the brake lights?
i had the same problem, you have an exposed wire that keeps blowing your fuse. My breaklights and horn are on the same fuse and both didn't work. I am not sure if thats the same w/ ur model but if ur horn doesnt work, its ur fuse.
Puppetkirk
Jun 19, 2005 07:57 AM
