zip tie your shifter cables?
Old Apr 9, 2005 | 08:57 AM
vtec_lude's Avatar
Default zip tie your shifter cables?
Hi guys, I read something about using zip ties to connect the shifter cables together to make it feel more positive, but I'm not sure how to go abouts doing it?
where abouts do i zip tie them?
and how close together do i need to do it?
I've already changed the big bushing type things, so i just wanna know how to do this mod..
Thanks for the help!!
Old Apr 9, 2005 | 09:50 AM
951dc5's Avatar
Default Re: zip tie your shifter cables? (vtec_lude)
Hey where did u get that diagram?
Old Apr 9, 2005 | 09:56 AM
integra15's Avatar
I dont know about zip tieing, but I know if you remove the 4 rubber bushings under the shift assembly it is supposed to feel much better shifting.
Old Apr 9, 2005 | 10:19 AM
The Phil's Avatar
Default Re: zip tie your shifter cables? (Prelude951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">Hey where did u get that diagram?</TD></TR></TABLE>
Prelude FSM has it. I'm sure you can find it online too.
Old Apr 9, 2005 | 11:22 AM
94Vtecluder's Avatar
Default Re: zip tie your shifter cables? (xthephilx)
Screw it drain the MTF as well.
Old Apr 9, 2005 | 02:54 PM
vtec_lude's Avatar
I've already drained my transmission fluid. done the bushing (replaced them with bolts and washers. just wanna know if this really works as well cos i've heard it does from the hybrid guys... maybe i'll post over there as well.. thanks
Old Apr 9, 2005 | 06:35 PM
WillyG's Avatar
Default Re: (vtec_lude)
which bushings do you remove exactly? And how does this change the shifter feel? I have a neuspeed short shift adapter so is this mod still possible?
Old Apr 9, 2005 | 07:00 PM
vtec_lude's Avatar
remove 13.14 and 16 from the diagram... and replace with a shorter bolt and washer.. it feels great.
I did this today and only just went for a drive and feels so positive! do it.!!!
Very easy to do too!
Old Apr 10, 2005 | 04:51 AM
AdReNaLiN's Avatar
So whats the go with this Zip Tie thing?
Old Apr 10, 2005 | 08:39 AM
Cashis Lee's Avatar
Default Re: (AdReNaLiN)
Am I the only one who thinks this thread is just a big joke? Draining out the tranny fluid?? Zip-tie the shifter cables??
Old Apr 10, 2005 | 09:02 AM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_lude &raquo;</TD></TR><TR><TD CLASS="quote">I've already drained my transmission fluid. done the bushing (replaced them with bolts and washers. just wanna know if this really works as well cos i've heard it does from the hybrid guys... maybe i'll post over there as well.. thanks</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cashis Lee &raquo;</TD></TR><TR><TD CLASS="quote">Am I the only one who thinks this thread is just a big joke? Draining out the tranny fluid?? Zip-tie the shifter cables??</TD></TR></TABLE>
A lot of the hybrids, you either run the shift linkage through the firewall, or under the car and back up. If you run it under the car, you can zip tie the together.
Old Apr 10, 2005 | 09:18 AM
high_revs's Avatar
so in a lude chasis you wouldnt be able to zip tie em? i've been wondering about this for a while myself.
Old Apr 10, 2005 | 11:03 AM
2point2's Avatar
you can get those from.. http://www.hondaautomotiveparts.com
it's great for looking at assemblies and comparing part #'s.
Old Apr 10, 2005 | 11:20 AM
4.6LJeepXJ's Avatar
Default Re: zip tie your shifter cables? (2point2)
Draining your transmission fluid is probably one of the worst ideas I have ever heard in my life. The length of time that your parts will manage that abuse will be minimal. I cut a slice in a 1/4'' washer then cramped it onto the clutch cable of a saab to remove some slopbut im not sure about the effectiveness of this method in your project.
Old Apr 10, 2005 | 03:48 PM
vtec_lude's Avatar
yeah i agree draining the trans is ust stupid. so basically this zip tie mod doesn't really work for the prelude?
Old Apr 10, 2005 | 06:55 PM
high_revs's Avatar
it should...i dont know why it wouldnt...
Old Apr 11, 2005 | 07:23 PM
Slatelude's Avatar
Default Re: (h23 killa)
Dunno about the zip-tie thing, but I just did the bushing replacement, and this is what I used (think it might be a slight improvement to just washer/bolt)
4 - nylon washers 1.75 O.D., .310 I.D., and .125 thick @ .63 ea.
---these go below the plate to space it up and relieve metal/metal rub
8 - metric 8 regular washers---two per mount to space the upper and lower washers and keep the bolt centered @ .16 ea.
4 - 5/16"x 1-1/4"O.D. fender washers---to fit on top under the bolt head @ .16 ea.
4 - M8x25mm w/ 1.25 pitch @ 1.06 ea.
Much better stiffness in shifts and thats just street driving, havent even gotten on it and been able to rip through the gears, all for $5.70
K
Old Apr 12, 2005 | 06:45 AM
Daemione's Avatar
Default Re: (Slatelude)
Yeah, I really don't understand what possible benefit zip-tieing shift cables together would provide . . . In a stock car it's not like they're flopping around & need to be secured somehow. In a swap, sure . . . .
Old Apr 12, 2005 | 11:57 AM
mgags7's Avatar
really bet you read a b-series or some other page for linkage shifters.....they would benefit from this because it would be harder to move the shifter with the linkages ziptied....
either way it sounds stupid.....
Old Apr 12, 2005 | 12:58 PM
Shakes's Avatar
space cadet
Default Re: (preludeserge)
some people on this board completely amaze me lately.
when people say zip tie the shift linkage here is what you do.
get a bag of zip ties.
jack the car up
remove nuts holding heat shield up. see those two black cables? take a zip tie, and put it around them, holding them closer together.
tighten the zip tie.
cut the excess tail off.
do that about every 4" all the way from the chassis to the engine bay where the shift cables connect to the top of the tranny.
this holds the shift cables more so they don't flex as much. thus resulting in a tighter more precise shift.
then replace the heat shield
lower the car
test drive
Old Apr 12, 2005 | 01:15 PM
pentaq's Avatar
Default Re: (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">
remove nuts holding heat shield up. </TD></TR></TABLE>
Which heat shield? Where? don't get it...
Old Apr 12, 2005 | 01:17 PM
Shakes's Avatar
space cadet
Default Re: (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">
Which heat shield? Where? don't get it...</TD></TR></TABLE>
on the 5th gen at least there is a heat shield that covers the cat, its attached to the chassis. its right behind the steering rack.
Old Apr 12, 2005 | 01:30 PM
pentaq's Avatar
OK. That **** rusted out of my car All clear, solder
Old Apr 12, 2005 | 01:33 PM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">some people on this board completely amaze me lately.
jack the car up
lower the car
test drive</TD></TR></TABLE>
Very well said! I noticed a difference when I zipped tied mine a long time ago.
Old Apr 12, 2005 | 02:07 PM
high_revs's Avatar
im doing this tonight
CTR-GSR
Feb 24, 2006 09:47 PM
realis9
Jan 19, 2006 05:30 AM
casmello
Jun 22, 2005 04:01 PM
jdmjay04
15
Mar 19, 2004 02:40 PM
InTeGrA_bLazEd
Oct 5, 2003 04:00 PM
