When clutch is engaged, RPMs drop to close to 0
Old Apr 9, 2005 | 08:55 AM
Its me DUB's Avatar
Default When clutch is engaged, RPMs drop to close to 0
Hey guys, like the title says: When I am driving, no matter what gear or how fast, when I push in the clutch to change gears or just put in the clutch to coast or something, the RPMs fall to close to 0. It makes driving very bumpy. Has this ever happened to anyone? Anyone give me suggestions for where to look? Thanks!
Old Apr 9, 2005 | 09:51 AM
CRX_Control's Avatar
Default Re: When clutch is engaged, RPMs drop to close to 0 (doitdub)
does this happen when you sit at a stop light? sounds like you arent getting enough air into your engine.
Old Apr 9, 2005 | 09:52 AM
three stars, two bars's Avatar
From: knee deep among your wreckage and uncertainty
Default Re: When clutch is engaged, RPMs drop to close to 0 (CRX_Control)
Did you adjust your IACV?
Old Apr 9, 2005 | 10:01 AM
bagpipe goatee's Avatar
do you have a lightened flywheel/crank pulley? because that'll decrase the rotational inertia and let the revs drop faster.
Old Apr 9, 2005 | 10:19 AM
eda6's Avatar
Default Re: When clutch is engaged, RPMs drop to close to 0 (iheartmyceeareks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartmyceeareks &raquo;</TD></TR><TR><TD CLASS="quote">Did you adjust your IACV?</TD></TR></TABLE>
how would you do that? There's nothing to adjust!
Anyways, I think your idle speed is too low. Try increasing it.
Old Apr 9, 2005 | 11:21 AM
Mach69's Avatar
Default Re: When clutch is engaged, RPMs drop to close to 0 (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
Anyways, I think your idle speed is too low. Try increasing it.</TD></TR></TABLE>
I think he meant clean it. And meant adjust your tps. Make sure it reads ~.5v at idle. And 4.5V at full throttle.
Old Apr 9, 2005 | 12:29 PM
mrquimbie's Avatar
Default Re: When clutch is engaged, RPMs drop to close to 0 (Mach69)
I would look at the iacv first. And second, what's the condition of your tranny? The throwout bearing may be freezing up. Just a thought.
Old Apr 9, 2005 | 12:54 PM
Zeppelin's Avatar
Are you saying that the car can be just idling in nuetral and you push in the clutch and the rev's drop? Or does it do it when you put it in gear?
Old Apr 9, 2005 | 01:15 PM
Its me DUB's Avatar
Default Re: (Zeppelin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeppelin &raquo;</TD></TR><TR><TD CLASS="quote">Are you saying that the car can be just idling in nuetral and you push in the clutch and the rev's drop? Or does it do it when you put it in gear?</TD></TR></TABLE>
If it is neutral idling it idles around 750 rpm....if I put it in the clutch when it is in neutral it doesn't effect it.
some notes: we just built the tranny (ZC/Si gearing) so it should be good.
I have a stage 2 exedy racing clutch and fidenza lightened flywheel...I don't think the flywheel would cause it to change this much. I also have CAI so I should be getting enough air at least into the throttle body. Also, I have VAFC-1. Haven't really messed with it yet so could that be that it isn't set right?
it is immediately when the clutch is engaged...doesn't matter what gear or how high rpms. and then when I release the clutch after putting into the next gear, the rpms shoot up so it is very bumpy. should i try with the IACV and TPS?
Old Apr 9, 2005 | 05:05 PM
mead441's Avatar
i had an idling problem in mb16 and i took my iacv off my d series and it fixed it. it bollted right up to the p&p intake manifold i just put on also. try that if necessary. good luck
Old Apr 9, 2005 | 05:12 PM
Its me DUB's Avatar
Default Re: (mead441)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mead441 &raquo;</TD></TR><TR><TD CLASS="quote">i had an idling problem in mb16 and i took my iacv off my d series and it fixed it. it bollted right up to the p&p intake manifold i just put on also. try that if necessary. good luck</TD></TR></TABLE> maybe i need some clarification here....
Old Apr 10, 2005 | 08:44 AM
Its me DUB's Avatar
Default Re: (doitdub)
bumpiddy
STEVE-O7
Oct 10, 2007 05:18 PM
skata89
Apr 6, 2007 08:39 AM
Lauj87
Sep 19, 2005 12:01 PM
happy_guy
Sep 10, 2005 10:28 PM
kseriesDC5
Mar 24, 2004 08:11 AM
