f22b1 into 90-93 accord.... Anyone done this??
Old Apr 9, 2005 | 08:00 AM
quick gixxer's Avatar
Default f22b1 into 90-93 accord.... Anyone done this??
well i posted this in the Hybrid section as well but i though i would give the accord section a poke at it.... hope that's ok....
Well i'm sure there are plenty of people out there who have done this swap... I was just wondering what it all involves because i have not found a good write up on it from anyone who has done it.... I think that you might have to modify the drivers side mount, and someone said to me that you will only have to change one wire for vtec, but again i am not sure.... any help or anyone who has done this your imput will be greatly appreciated...
The reason that i want to do this swap is that my stock motor and tranny in my 92 Dx are about shot, and i have a friend that just swapped a h22 into his 94 accord and he will give me the engine, tranny, and ecu for like $200 in perfect working order, so this would hopefully revive my otherwise tired old accord into a descent well running daily driver. Or that's the thought anyway
Old Apr 9, 2005 | 08:41 AM
Default Re: f22b1 into 90-93 accord.... Anyone done this?? (quick gixxer)
sounds like you have to swap pins a6 and a11.... Is this all??? I'm just curious about all the other stuff like axles and mounts and what not
Old Apr 9, 2005 | 04:20 PM
sonlyte's Avatar
I have but havent worked out all the kinks. You can reuse you axles though. You will need drivers side engine mount off f22b1. if you have ex trim the engine exhaust pipe will bolt right up. must get ecu and run wires for vtec sol. and map sensor.
2005ineedhelp
Dec 5, 2023 07:36 PM
PWRDbyHseries
Nov 14, 2006 09:33 PM
gdup503
Jun 6, 2006 11:32 PM
alupso
Jan 30, 2006 07:31 PM
