driver window tilts when i roll it up
you probably need to get a new window regulator, or check the 2 brackets that the window sit in, maybe they got heated up and the glass slipped out. hope this helps.
You can remove the inside door panel and apply WD40 on the guide rail to make it more likely to slide and not get caught. Some times the guide rail gets out of wack and the window hits something inside the door. Wd40 usually will do the trick though.
Window regulators more than likely, i'm having the same problem also but i'm not going to fix it because i may sell my car, try H-Auto, they may have the regulators in stock for like $45.00 each side.
My driver side is doing the same thing. Except it's worse than you describe. Looks like I have the wrong glass, but it's not wrong. Annoys the hell out of me cause even when I roll it up all the way, rain still gets in my car. Big crack on the top and bottom for water to get in.
teh suck
teh suck
This happened to me! THe window didn't seat properly in the window trim at the front part of the door. Got worse after a while and the gap grew from about 1/2" to about 2". Ended up taking apart the inside of the door to get at the regualtor. Turns out my window glass came out of the regulator in front.
i-want-a-crx
Oct 13, 2007 08:41 AM
