check engine light- solid light on ECU
Old Apr 9, 2005 | 06:54 AM
naptownrex's Avatar
Default check engine light- solid light on ECU
Ok, I just replaced the rotor yesterday, becaue it slipped off the shaft, and i got stuck on the side of the road. the car was running good, but after driving for 1/2 hour, the car would like bog when im just cruising. Its very quick, and then its fine. then the check engine light came on, the ECU just had the solid, unblinking led on- which i heard is a sign of a bad ECU. the light stayed on for a mile or two, then went off. btw, its a 88 crx si with a b16a swap and pr3 ECU. anybody got any ideas? just did tune up and fuel filter too.
Old Apr 9, 2005 | 09:36 AM
CRX_Control's Avatar
Default Re: check engine light- solid light on ECU (naptownrex)
the light wont blink while your driving...you have to look at your ecu to see what its blinking while your car isnt going anywhere but the power is on.
Old Apr 9, 2005 | 10:18 AM
mr. carpenter's Avatar
Default Re: check engine light- solid light on ECU (CRX_Control)
reset your ecu and see if it's throwing a code.
Old Apr 9, 2005 | 10:23 AM
Burlyirishdude's Avatar
Default Re: check engine light- solid light on ECU (mr. carpenter)
if she's olid...she's fried dude...but reset and see if that helps.....Just pull the battery cable off for about 15 secs...
Old Apr 9, 2005 | 10:27 AM
TIRENECK's Avatar
Default Re: check engine light- solid light on ECU (Burlyirishdude)
it wouldnt run if it were fried.
Old Apr 10, 2005 | 06:43 PM
91T-Rex's Avatar
Default Re: check engine light- solid light on ECU (TIRENECK)
i've had a fried ecu still allow me to drive my car. actually it was a chipped pr3
i agree with everyone else. reset, and see how it goes. solid means shes bad.
scott
Old Apr 10, 2005 | 06:59 PM
jdmb16efhatch's Avatar
Ive had the light blink while driving.
Old Apr 10, 2005 | 07:36 PM
Civic138's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">the light wont blink while your driving...you have to look at your ecu to see what its blinking while your car isnt going anywhere but the power is on.</TD></TR></TABLE>
yea man,i've had mine blink when i drive (no carpet,so i know it's blinking)
Old Apr 10, 2005 | 08:39 PM
oldschoolfreak's Avatar
not true mine blinks while i drive im 100% sure about that too.
Old Apr 11, 2005 | 05:12 PM
naptownrex's Avatar
Default Re: check engine light- solid light on ECU (oldschoolfreak)
wither way, I reset the ECU, and its still coming on after its gotten warmed up. It'll come on for like 5 secs, the first time, go off, 5 mins later, it'll come on for a lil longer, and so on and so on. The car bogging is what really concerns me though- could this be caused by a bad ECU?
Old Apr 18, 2005 | 08:26 PM
A bad ecu will mess up alot of ****, if it will even let it run past 2-3k rpms.
Mesm23
Jun 13, 2017 09:11 AM
1320king
Jul 22, 2007 12:32 PM
jason_alt
Mar 3, 2004 07:08 PM
hybridb18
Mar 29, 2003 09:12 PM
andrew dc
Aug 18, 2001 03:40 AM
