HELP CAR WONT START
Old Apr 9, 2005 | 05:38 AM
blks2k3's Avatar
Default HELP CAR WONT START
The car is a 95 gsr. I got in it and tried to start it but nothing happened. The car is not even turning over. I tried to roll it off and jump it off but nothing. The windows does not roll down, the lights on the instrument panel does not light up, and the wipers dont work. The radio and dome light does work. I have checked all fuses inside and out, had the battery charged, checked the plugs, test light the ignition switch, and checked all grounds. What could it be?
Old Apr 9, 2005 | 07:56 AM
-Darren-'s Avatar
Default Re: HELP CAR WONT START (blkgsr3)
could be your starter or alternater, i'm not sure.
Old Apr 9, 2005 | 03:46 PM
h22_cx_hatch's Avatar
is there crank?
Old Apr 9, 2005 | 10:35 PM
veganej's Avatar
sounds like it may be the starter if your not even turning. but i dont know why that would cause the panels and wipers not to work. that sounds like a fuse. maybe under the hood. or a bad relay.
Old Apr 10, 2005 | 08:01 AM
sabotage7's Avatar
check your wires and terminals that connect to the battery, maybe they're corroded or something. have you tried disconnecting the battery and checking the voltage, and then reconnecting it and testing the voltage thru the terminals? maybe try that, if theres a difference, then maybe its your terminals and/or wires.
good luck!
si90rex
14
Apr 29, 2009 06:12 PM
92VXeg
38
Aug 30, 2007 08:15 PM
MonkeyMagic
Apr 30, 2005 03:08 PM
90LSpimpin
Oct 6, 2004 10:06 PM
