picture request map sensor, fuel pressure regulator
Old Apr 8, 2005 | 11:33 PM
ef_you_again's Avatar
Default picture request map sensor, fuel pressure regulator
help search no good
Old Apr 9, 2005 | 11:57 AM
Old Apr 9, 2005 | 12:48 PM
Gumbey75's Avatar
Default Re: (ef_you_again)
heres a map sensor.
Old Apr 9, 2005 | 01:26 PM
eda6's Avatar
Default Re: (Gumbey75)
The fpr is above the #2 runner
Old Apr 9, 2005 | 10:03 PM
wheres the map sensor located. and what is a #2 runner. can a car run without a map sesnor? cuz i dont think i have one
Old Apr 9, 2005 | 10:40 PM
99sonicbluegsr's Avatar
your map sensor is located on your firewall next to the charcoal canister, (black cylinder on left side of firewall), unless relocated. the number 2 runner is refering to the part of the intake manifold that goes the the number 2 cylinder,( 4-3-2-1), or it is the only thing on your fuel rail that has a vacume hose on it. hope this helps.
Old Apr 11, 2005 | 08:04 AM
i dont have a charcoal canister and i dont think i have a map sensor either so how do i put one on
Old Apr 11, 2005 | 08:08 AM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_you_again &raquo;</TD></TR><TR><TD CLASS="quote">i dont have a charcoal canister and i dont think i have a map sensor either so how do i put one on</TD></TR></TABLE>
Your car needs a map sensor to run properly. Otherwise you will constantly have a check engine light and the car will run crappy.
Old Apr 11, 2005 | 08:17 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Here is a shot of the map sensor in its stock location:
Old Apr 11, 2005 | 10:46 AM
2kTeg's Avatar
Default Re: (88DXCRX)
i have a stock map sensor for sale cheap if you end up needing one
Old Apr 11, 2005 | 11:38 AM
Mach69's Avatar
Default Re: (91civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">
Your car needs a map sensor to run properly. Otherwise you will constantly have a check engine light and the car will run crappy.</TD></TR></TABLE>
Or he could have a newer throttle body with the map sensor on the t/b. That is doubtful. You probably have it there, you just don't see it.
Old Apr 11, 2005 | 11:57 AM
no i dont have it. and i DO have a check engine light. and my car DOES runny crappy sometimes
Old Apr 11, 2005 | 01:25 PM
ok so one hose goes to the throttle body.. what about the other end of the hose where does that go?
Old Apr 11, 2005 | 01:30 PM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_you_again &raquo;</TD></TR><TR><TD CLASS="quote">no i dont have it. and i DO have a check engine light. and my car DOES runny crappy sometimes</TD></TR></TABLE>
What is the error code for? Can you post pictures of you engine bay, the firewall, and the vacuum connections?
Old Apr 11, 2005 | 01:32 PM
92integra_gs's Avatar
i would get a helms by now...
Old Apr 11, 2005 | 01:34 PM
EP3_05's Avatar
Default Re: (92integra_gs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs &raquo;</TD></TR><TR><TD CLASS="quote">i would get a helms by now... </TD></TR></TABLE>
Helms=
Buying the service manual was the greatest mod I made to my car.
Old Apr 11, 2005 | 03:11 PM
vegaskurt's Avatar
and dont buy the haynes manual... it sucks
Old Apr 11, 2005 | 03:26 PM
88DXCRX's Avatar
Click here:
Save this picture then magnify it....
The hose goes into a TEE that has a plug in it...
One hose straight from the throttle body
to the map sensor will work just as well..
Old Apr 12, 2005 | 08:07 PM
i have the shop manual for crx and integra but my throttle body doesnt look like the ones in the picture. I also dont have a charcoal canister car bogs occasionally CEL code 13
Old Apr 12, 2005 | 09:08 PM
CRX_1.8T's Avatar
Default Re: (vegaskurt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">and dont buy the haynes manual... it sucks</TD></TR></TABLE>
The Hayne's manual has actually has been proven to lower one's intelligence.
Anyways, which engine did you have in there? And, where did you get it if it isn't stock?
Old Apr 12, 2005 | 09:42 PM
doublethink's Avatar
Default Re: picture request map sensor, fuel pressure regulator (ef_you_again)
if emmisions doesnt matter to you, you can run with nothing BUT the map sensor and fpr, thats how i run my b16a currently.
the FPR needs vaccum, so run a line from the output of the manifold to the fpr. in this image here they use a t-fitting to go to the bullshit on the fire wall, really not needed. i just ran it straight to the fpr.
the map needs to to be connected as seen here: (the left on the firewall, you can ignore the right)
charcoal and dashpot you can ignore. make sure if you have that rare funky manifold pictured there that you plug up any un used openings in the manifold, like the one circled in red..
that being said, if youd like to have some hope of legally passing emissions and whatnot, follow that diagram.
"vacuum" hits 97 threads with archive checked in crx section, lots more info to be found there, thats how i got the info to finish mine.
boostedcivicsir
Oct 26, 2008 02:14 PM
kpowerdhatch
Oct 20, 2007 02:43 PM
GhostInTheShell
Mar 19, 2007 05:25 PM
zman
Jun 15, 2006 07:40 PM
JonGP4
12
Sep 9, 2003 06:59 AM
