Camber Adjustments - for the track
Couple of questions here.
1. For road racing, what have you found to be the best camber numbers front and rear?
2. What is a reasonable way to achieve camber adjustability?
I have a GC / Bilstien setup so I have some adjustablility there.
Chris
Chris
I'd like to know what tires and size, what spring rates, which anti sway bars, what track surface and corner weights?
[Modified by DB1-R81, 9:30 PM 1/28/2002]
- 15x7 Kosei K1's w/ 205/50/15 Toyo RA1's shaved to 4/32
- 600lb front and 900lb rear springs
- stock front swaybar, 26mm Mugen rear swaybar
- asphalt (?!)
- I don't know what the corner weights are, sorry.
Andrew, for a second I thought you were describing my setup!
I have 225/50 15 Toyo RA1 on K1 15X7
500f 600r
Stock swaybars
asphalt/concrete road courses like Summit Point / VIR / Mid-Ohio / LIMEROCK
Thanks
500f 600r
Stock swaybars
Thanks
Natural Aspirations
27
Jul 17, 2011 04:06 PM
Jon777
Suspension & Brakes
May 10, 2011 10:23 AM
kcem1
Suspension & Brakes
11
Oct 27, 2005 03:34 PM
