car dead, constant CEL
Old Apr 8, 2005 | 04:39 PM
DarkBB4's Avatar
Default car dead, constant CEL
Ok, here goes. Warmed my car up, on my way to work, i had to stop, so i set it in neutral and then it stalled. Then i tried to restart and it cranks over, but wont catch
Now i have a constant CEL and the car is dead, on a main road. HELP
what could it be?
Old Apr 8, 2005 | 05:24 PM
dmxsoulja3's Avatar
Default Re: car dead, constant CEL (DarkBB4)
IIRC solid with no flashes is Code 0 - and problem with the ECU itself.
Old Apr 8, 2005 | 05:26 PM
DarkBB4's Avatar
Default Re: car dead, constant CEL (dmxsoulja3)
im going to yank out the VAFC, can i just unplugit from the harness? or should disconnect all the wires?
Old Apr 8, 2005 | 05:30 PM
dmxsoulja3's Avatar
I can't be for sure on the vafc, iirc some of the wires are double tap'd like in a series type deal on the same wire.
Old Apr 8, 2005 | 05:32 PM
DarkBB4's Avatar
well car has been running fine with vafc for bout 6 months
could it havea nything to do with timing belt?
spark plugs?
Old Apr 8, 2005 | 05:36 PM
dmxsoulja3's Avatar
looking over my obd1 codes it says sold MIL is ECU, the only other time I see it on is when I jump the ecu check harness to set timing and the car is running
Old Apr 8, 2005 | 05:39 PM
dmxsoulja3's Avatar
keeping in mind its solid because you are checking the code, the light stays solid because there is a problem, it only shows the blinks if the connector is jumped. Is it solid all the time, or solid when you jump the connector
Old Apr 8, 2005 | 05:44 PM
DarkBB4's Avatar
solid when the car is like half on(Not starting, but elec **** is on) ..
and when i jump it, the abs codes are blinkin and ****, so iknow im doin it right.. But the CEL is just solid, never turned off
Old Apr 8, 2005 | 05:47 PM
dmxsoulja3's Avatar
The CEL stays solid if there is a problem, if you jump it and it stays solid its the ECU, if you jump it and it flashes get the code and reply.
To stop it from coming on solid all the time, you have to reset it...negative battery cable or the clock/radio fuse
Old Apr 8, 2005 | 06:46 PM
DarkBB4's Avatar
alright well i disconnected battery for a few minutes then hookd back up, same thing solid CEL
jumped it, SOLID CEL
The oil and battery lights are on too
i puled the plugs, and they were fine
HELP
I also disonnected VAFC harness (just unclipd) and did nothing
also fkd around with wiring, everythign seems fine and intact
HELP
Old Apr 8, 2005 | 06:54 PM
dmxsoulja3's Avatar
I'm telling you man, solid when jumped is CODE 0 - ECU look it up.
Old Apr 8, 2005 | 06:55 PM
DarkBB4's Avatar
so what does that mean!!!
randomly my ecu just **** itself?
it has to be soemthing major!
Old Apr 8, 2005 | 07:09 PM
dmxsoulja3's Avatar
shorted out or something who knows...I would find a known good one, even an h23 or something just to see if the car starts. Of course don't drive it like that.
Old Apr 8, 2005 | 09:34 PM
VTECRaZeR's Avatar
Did you check for actual spark? Check for power at the coil?
Have you checked if you are getting a signal to your fuel injectors?
If you can't get the thing to work or don't know to test this things try pulling the code, if it's a hard code I'll tell you what it is and you can go from there
Old Apr 8, 2005 | 10:33 PM
PrettyLude's Avatar
Default Re: car dead, constant CEL (VTECRaZeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmxsoulja3 &raquo;</TD></TR><TR><TD CLASS="quote">I'm telling you man, solid when jumped is CODE 0 - ECU look it up.</TD></TR></TABLE>
solid when jumped means that there are no stored codes, your ecu is fucked, when you jump the code, and the light does not come on, that's code zero
Old Apr 9, 2005 | 03:28 AM
DarkBB4's Avatar
Default Re: car dead, constant CEL (PrettyLude)
will a jdm obd1 p13 work ok? or obd2 p13 JDM work?
Old Apr 9, 2005 | 07:37 AM
dmxsoulja3's Avatar
qouted"
It's complicated. Well, really it isn't.
If you get a solid CEL and jump the connector, and it is solid, that means bad ecu.
If you get no solid CEL, and jump the connector, and THEN get a solid CEL, that means everything is ok.
So If you get an unjumped solid cel, don't turn the car off. Jump it, and read the codes without turning the ignition off.
Intermittant running codes may get reset when you turn the car off, hence getting a "NO CELs" solid CEL."
Old Apr 9, 2005 | 01:44 PM
DarkBB4's Avatar
I just hooked up a JDM p13 and it still was a constant CEL
no different
HELP PLEASE! i dont want to get it towed from a shop
Old Apr 10, 2005 | 12:55 PM
DarkBB4's Avatar
Removed VAFC and i still cant get a code
PLEASE HELP
I can post a video of everythign if u want
SPARK? FUEL? how can i tell?!!!
anything to do wthi the timing belt?
Old Apr 10, 2005 | 01:09 PM
DarkBB4's Avatar
NO SPARK!
Old Apr 10, 2005 | 01:16 PM
Shakes's Avatar
space cadet
when you unhooked the vafc, did you take the wires out and then rewire the car back to stock?
Old Apr 10, 2005 | 01:36 PM
DarkBB4's Avatar
Default Re: car dead, constant CEL (Shakes)
yea i rewired it back to stock... un hooked each wire individually and put back where it was!
what is up with teh ECU, it is a constant CEL no matter what i do... i cant get it to show a code
Old Apr 10, 2005 | 02:16 PM
AndyD's Avatar
Bad ignition coil??
Old Apr 10, 2005 | 02:33 PM
DarkBB4's Avatar
Default Re: car dead, constant CEL (AndyD)
how can i test that? and how can i test a bad dizy?
would u like me to take a video of how the cel looks and etc?
Old Apr 10, 2005 | 03:23 PM
DarkBB4's Avatar
http://www.we-todd-did-racing....DE%3D
