Mallory RPM Activated Switch Install
Old Apr 8, 2005 | 04:35 PM
91_CRX's Avatar
Default Mallory RPM Activated Switch Install
Ive looked all over the internet. Ive found mr.gasket.com and supposedly mallory is a part of mr.gasket?
Anyways Ive been looking for a while and cant find anything on installation. I need this in today! If anyone can help it would be great.
its a "Mallory Ignition RPM Activated Switch" part number #627A
Please any help is appreciated.
thanks
edit: looks like this:
link to mr.gasket:
http://go.mrgasket.com/Product...ction=
Old Apr 8, 2005 | 04:37 PM
CRXVTEC69's Avatar
Default Re: Mallory RPM Activated Switch Install (91_CRX)
please dont tell me ur using this to activate VTEC in your car.............
Old Apr 8, 2005 | 04:53 PM
91_CRX's Avatar
Default Re: Mallory RPM Activated Switch Install (CRXVTEC69)
yes why?
Old Apr 8, 2005 | 04:56 PM
menappi's Avatar
cause thats ghetto. get the ecu or a vafc at least. that switch wont adjust fuel levels accurdingly.
Old Apr 8, 2005 | 04:58 PM
91_CRX's Avatar
Default Re: (menappi)
im getting my pm6 chipped for p28 fuel maps and all but i need this to activate vtec
Old Apr 8, 2005 | 05:02 PM
91_CRX's Avatar
Default Re: (91_CRX)
need help! i dont need to be told its crap, all i need is instructions!
Old Apr 8, 2005 | 05:10 PM
menappi's Avatar
uhm im not sure, do a search im sure they are all pretty much teh same. u might want a relay in there. also your going to run lean, but if you dont care then thats fine. id assume the red it 12v, black is ground, the blue might from the tach, and the rest i dont know.
Old Apr 8, 2005 | 05:15 PM
91_CRX's Avatar
searched a lot and only found another one which was pretty much the same but it gives stupid driections for nitrous and other things i cant use. Nothing in there for a vtec engage.
also there is no blue wire
Old Apr 8, 2005 | 05:31 PM
91_CRX's Avatar
found a good similar one ill try the setup i found today, ill bump the thread if it doesnt work
philkehn
10
Oct 3, 2006 11:55 AM
blkhatch92
Nov 21, 2005 05:25 AM
2G0S0R1
Dec 13, 2003 11:05 AM
