1997 Accord EX 4-cyl timing belt woes
Hi,
First I want to say....Awesome Forum!
Now, here's my dilemma.
Against my better judgment, I had the timing belt/water pump replaced by a
'friend of a friend'. Now, the engine seems to be a bit down on power and
it's got a pretty noticeable vibration at speed.
I know...I already feel stupid...
I took it back to the 'friend of a friend' and he rechecked to see if
everything was lined up. And..lo and behold...he says all is normal. UGH!
While I'd like to administer a baseball bat to his cranium, I know that
it's ultimately not worth it. So....
Am I totally screwed? Anyone know any good shops in Northern NJ that can do this at a price I can live with (since I've already spent a dencent amount of $ on this)?
Thanks in advance!
Jim
Modified by JMK3rd at 7:05 PM 4/8/2005
Thanks in advance!
Jim
if the balance shaft belt is off 1 tooth it with shake..... and if the cam timing is off 1 tooth (about 12 deg.) you will expirience a drivability problem, laggy/lack of power and maybe even spark knock if it is advanced
$700 for a new radiator, coolant, timing/balancer belts, water pump.
It was a freezing day......my radiator was pissing steam...and i needed to get back home from work (75 miles). I should have listened to the voice in my head and just had the radiator done. But.....noooooooo
jnb0111
Jun 8, 2011 07:36 AM
patrickvertigo
Aug 7, 2010 07:23 AM
Stew Pidasso
Jan 2, 2008 04:41 AM
