RPM test connector question
Old Jan 28, 2002 | 05:56 PM
GruvyTune's Avatar
New User
Default RPM test connector question
Hey,
I went to dyno my car and they connected their dyno to my RPM test connector at the driver's side under the hood. For some reason, their measurements were all over the place at higher rpms. My rpms measure fine on my dashboard tach. The helms manual shows the blue test wire to come from the distributor's ignition control module directly. What could be the problem? Have other's used this wire without problems?
thanks!
Old Jan 28, 2002 | 06:40 PM
Stock R's Avatar
Default Re: RPM test connector question (GruvyTune)
that's the wire.
a lot of ppl actually use that wire to control their aftermarket tach's.
DaDevil
Mar 30, 2007 05:28 PM
slimjimdanny
Jan 31, 2007 07:35 PM
nighttime
Oct 26, 2002 02:21 PM
yodude
Jul 13, 2002 02:52 AM
GruvyTune
Jan 29, 2002 12:36 PM
