rear brake caliper help
Old Apr 8, 2005 | 10:37 AM
VTECsop's Avatar
Default rear brake caliper help
i changed the pads on the drivers side. the caliper compressed back into the cylinder fine. on the passenger side, the caliper does not want to compress all the way. i get it in most of the way but no matter how many times i use the rachet and the universal adapter the caliper does not want to compress. what should i do. anyone else have this problem before???
Old Apr 8, 2005 | 01:45 PM
deserthonda's Avatar
loosen up the bleeder screw and see if you can compress it ,,,you might have to bleed that side
Old Apr 8, 2005 | 02:23 PM
VTECsop's Avatar
Default Re: (deserthonda)
i did that but i didn't try too hard because i didn't want to have to bleed it. but if i can't fix it tonight I'm going to try again. thanks though.
anymore ideas are appreciated
Old Apr 8, 2005 | 03:49 PM
hotaccord243's Avatar
Default Re: (VTECsop)
did you try it with the handbrake off, you prob already have but just checking
Old Apr 9, 2005 | 06:15 AM
VTECsop's Avatar
yeah i had the ebrake off. but yeah i loosened the bleeder valve and i got it to go in. my arm was killing me after but it went back into the cylinder. i bled the brake after but yeah it worked out. thanks for the help.
~~~~~got bass????
mish__
Suspension & Brakes
12
Apr 5, 2012 03:40 PM
ekej699
Suspension & Brakes
May 24, 2011 07:13 AM
bonspeed
Dec 20, 2009 12:34 PM
HFpower
Feb 17, 2007 04:58 AM
justforkicks
Sep 16, 2006 06:18 AM
