k20a in a crx would it pass a state ref?
Old Apr 8, 2005 | 07:45 AM
burnt_rice's Avatar
Default k20a in a crx would it pass a state ref?
i'm just wondering if a k20a would pass the state ref exam...because of this concern and many people have already told me that you can or you can't ref a k20a I'M Leaning more towards the h22a swap since that is ref-able...but i just wanna know out of curiousity plus if it does i may go for that later on down the line.
Old Apr 8, 2005 | 09:37 AM
Mr_CRX's Avatar
Default Re: k20a in a crx would it pass a state ref? (burnt_rice)
I dont see why it wouldnt, assuming you had it all wired up like it came in an RSX or Civic Si. Would a JDM k20a pass? I'm not sure about that.
The only advantage I see with the h22 is that you could stay obd1.
Old Apr 8, 2005 | 09:43 AM
DJ_SaNdOz's Avatar
Default Re: k20a in a crx would it pass a state ref? (Mr_CRX)
If I understand teh CA laws correctly it would pass as long as all of the vaccum lines, electronics, ecu etc is in functioing order as it would be from teh donor car.
Old Apr 8, 2005 | 09:46 AM
Rywire's Avatar
Hmm, I am not sure about that for 2 reasons.... However I have yet to do a k20, so I am not an authority by any means.
The kpro being 1, does that fly with the ref?
The second being the fuel regulator/ lines. There is no CARB cert fpr on the market, is there??
What other opinions are out there?
Ryan
Old Apr 8, 2005 | 10:26 AM
Mr_CRX's Avatar
Default Re: k20a in a crx would it pass a state ref? (droppedcrxsi)
I'm unfamiliar with the k-pro. Is it all inside a standard "K" ecu? or is it something separate, because at the Ref I went to, he just checked to see if it was a P72 ECU. They didnt' open it to see if it was chipped/modded/etc.
Ryan, IM me about the fuel lines and such. I'd like to know what is involved with that.
Old Apr 8, 2005 | 11:34 AM
DJ_SaNdOz's Avatar
kpro should be fine, people in Type S' & Si's are passing w/ that installed. Visually it should pass fine, and smog wise the numbers should be close to factory IIRC
Old Apr 9, 2005 | 10:59 AM
Rywire's Avatar
Default Re: k20a in a crx would it pass a state ref? (DJ_SaNdOz)
The fpr is not located on the fuel rail on a k, correct? So you must run a external? And there is no carb cert external fpr's correct?
Im still learning... but I hear that the fuel sytem differs, and can possibly cause problems at the ref. I would love to know this, someone please post if they can shead some light.
Ryan
thisiskev
Aug 4, 2009 09:10 AM
ketchup
Aug 30, 2008 09:01 PM
dapump2003
Jul 23, 2006 03:18 AM
zad5
Aug 24, 2004 08:57 PM
DIE DIE
Feb 27, 2004 06:30 PM
