Removing the Corner Lights, and lower lights on the EF??
Screws? How many? Where? For the corners beside the headlights and the lights below the headlights. Thanks
for the bumper lights just take out the 2 screws for each light
and for the corner, if it's a 88-91 just take out the 2 screws on the outside and slide it out
if your car is a 90-91 pop the hood and you'll see a small 10mm bolt i think holding it in,just take that out then slide it off
You can make that bumper lamp step above even shorter (at least on a 90-91 CRX), remove the outter screw only. The inner screw just holds the lens to the housing, so you can leave it in. There are plastic tabs on the housing that slot into the bumper for the inner fastening. Pull out the lamp and unplug the harness.
Corner lights are the easiest lights to take out JF, The bumper lights shouldn't be so shabby. I am replacing my clutch tomorrow on the civic, So if you need any help give me a shout on msn and I will pass by and give you a hand.
