anyone have a teeth count for m2f4 5th gear
Old Apr 7, 2005 | 08:42 PM
machine4321's Avatar
Default anyone have a teeth count for m2f4 5th gear
i boiught a tranny and theres no code on it ...
i need to know if any one has a usdm h22 4th gen 5th gear kicking around that they could count for me
i counted 5th gear on the main shaft and it had 31 teeth on it ..
want to make sure i have to right tranny and didnt get ripped off
Old Apr 7, 2005 | 08:43 PM
or help me figure out the ratio from the 31 teeth
thanks
Old Apr 8, 2005 | 06:18 AM
PirateMcFred's Avatar
Default Re: (machine4321)
You have a .871 ratio fifth gear. The gear (on the countershaft) that mates you your 31 tooth gear is 27 teeth. 27/31=.0871 loks like you have a nice transmission there.
M2S4 (32/26) and M2F4 (31/27) 5th gears and countershaft compliments:
Pirate
Old Apr 8, 2005 | 07:00 AM
your my hero ...
thanks alot just wanted to make sure i was sold the right tranny ...
ill have to get a pic up of the piece i found in ti ..looks like a very thin piston ring and smaller of course
but other then the 5th gear syncro being torn up it looks brand new ..not bad for 250 canadian ...but im gonna replce the shift fork and 5th syncro
thanks again
Old Apr 8, 2005 | 09:12 AM
check the circlips that hold the passenger side countershaft ball-bearing in. the one that you have to pop to get the transmisison apart. I had one break in my M2S4.
the bottom rightmost bearing...
Pirate
Old Apr 8, 2005 | 11:38 AM
yea you might be right ..ill check it out when i get home ..
is it the little steel thing in the top bearing your refering to ..
whats its purpose
thanks again man ..your a huge help
Old Apr 8, 2005 | 12:04 PM
That snap ring holds the countershaft in place. I have seen someone bolt the two transmission cases together without snapping that ring into place (like they were supposed to) and it busted a circular piece of aluminum out of the other side of the casing 2" in diameter.
Pirate
Old Apr 8, 2005 | 03:25 PM
jdmcivicferio's Avatar
told you it was a M2F4 tranny
Old Apr 9, 2005 | 04:14 AM
haha dam you ..
your werent supoosed to see this .... (kidding)
honestly i didnt really doubt you but i wanted to find out for sure while i was in there...thanks again mayo ....
the tranny is acctually in good shape inside except for this broken ring ..and the 5th gear syncro is pretty toast lol
3rds not to far behinde but im not complaning for the price i pad ..i raided a freinds h23 tranny for the slave vss and clutch lever ...for free so it worked out ok ..i even took his clutch bolts haha (im on a budget )
im gonna have to put it back togther as i dont have the funds right knw to get tha parts.
but it should be fine for a few months ..
thanks again
to pirate...will this prevent me from snapping the ring in when the case goes back on ...and how important is it really
Old Apr 10, 2005 | 07:37 PM
well guys its way worse then i thought
i knew 5th gear needed to be replaced due to the 5th gear grind problem ...so heres how it went
the clip was the 5th gear syncro spring (goes in between hub abd syncro ring)it hols the ring in the right spot ..so that broke and the ring drop a bit and 5th gear was only in the syncro hub about 1/4 of the way ....you can guess what happened after that ...there is nothing left of the 5th gear syncro hub and that why 5th was skipping even by hand ..not a big deal cause what i was going to replce would have been all that anyway
but, got looking into the rest and it turns out 3rd gear dog teeth are toast aswell as the 3rd/4th syncro sleeve is on its way out and 3rd and 4th syncro rings are done too ...all the hubs seem to be fine
2nd gear dog teeth are also gone as well as the ring and sleeve ...so all in all i paid 250 bucks canadian for a garbage tranny and al the guy says is it shifted smooth except for 5th ....so i hope i can salvage the gears and just replace the syncro rings and sleeves..i cant afford 1000 (canadian)dollar rebuild even though im doing it my self
all in all pretty shitty night ...was hoping to have a car next week or two but i guess it will be a few months now
Old Apr 11, 2005 | 04:49 AM
Damn, sorry to hear that. I would imagine that you could use some parts out of a H23 transmission as a donor. that might be cheaper. at least you found where the rest of that wire came from.
You use that transmission as the ultimate experiment for Penzoil/GM Synchromesh.
Pirate
Old Apr 11, 2005 | 05:16 AM
lol they will ahve to pay me
so i guess im gonna try and slavage the gears and just get the syncro rings and try to just get hte sleeves without the hubs cause there fine
i figure its gonna be the same amount to fix this (mabye less if im lucky)as buynig another used tranny 85% chance its gonna grind a gear or two ..
so i ll rebuild this one and sell it next year ..or when ever i can save up enough for a lsd tranny ...or hell mabye if the gears are ok ill just buy a lsd for this one
gonna call gearspeed soon and see what they say ..i dont think i can buy parts form hondo..just the gear sets and there 190 to 250 for a gear set, ill need a few gear sets lol
Old Apr 11, 2005 | 05:34 AM
yea and on the h23 tranny ..since the gears are different would the syncro rings and leeves be the same ?
i would guess they are
homey dont play dat
Jul 20, 2016 06:27 AM
brlabrune
Feb 23, 2009 12:37 PM
92eg6lsvtec
Jul 9, 2008 07:08 PM
machine4321
Apr 10, 2005 08:37 PM
6thgen4u2nv
Dec 31, 2003 02:00 PM
