vtec not working and a few easy questions
Old Apr 7, 2005 | 07:33 PM
overclocking1's Avatar
Default vtec not working and a few easy questions
i posted this in the integra forums but i didnt see these tech forums at the time so here it is.
im getting a code 21 and 23. i found a yellow and red wire unhooked and rehooked it to a sensor on the back of the block.then i got a code 23. then i found another sensor unhooked right above that on. its under the intake and screws into the block. any ideas.
96 gsr engine
Old Apr 7, 2005 | 09:28 PM
Evo-man@20psi's Avatar
Default Re: vtec not working and a few easy questions (overclocking1)
I shall return let me do some research
Old Apr 7, 2005 | 09:33 PM
Kendall's Avatar
Code 21 is for the VTEC solenoid and code 23 is for the knock sensor. The one that screws into the block is the knock sensor. Get it hooked up and check the wiring to the solenoid.
salman
Nov 18, 2008 05:27 AM
Joecivic94
Dec 5, 2007 05:01 PM
overclocking1
Apr 8, 2005 05:59 PM
dryhopsux13
Apr 8, 2005 06:02 AM
StupidSlowRSX
16
Oct 5, 2004 04:26 PM
