Transmission.
Old Apr 7, 2005 | 06:36 PM
HatchKid12's Avatar
Default Transmission.
Car is 1990 Hatch si, w/ Dohc Zc
Just replaced the clutch cause i "thought" that was the problem, But now im being told i need a new transmission
problems are that it wont go into gear bearly, and when it does it doesnt seem like its in gear...Example-I put it in 5th and yet it stills moves up and all around....all loose like..
How should i go about this..
Modified by HatchKid12 at 7:51 PM 4/7/2005
Old Apr 7, 2005 | 06:50 PM
HatchKid12's Avatar
Default Re: Transmission. (HatchKid12)
Bump cause i really want this fix for a good price or just knowing what the problem is so i can start pouring my money into other nice goodies
Old Apr 7, 2005 | 06:55 PM
dr_latino999's Avatar
Did you check that the clutch cable is adjusted correctly?
Old Apr 7, 2005 | 07:07 PM
HatchKid12's Avatar
Default Re: Transmission. (dr_latino999)
not a cable tranny...
Old Apr 7, 2005 | 07:57 PM
SiR Inspired ED7's Avatar
while your at it maybe you should replace your bushings. they might be wore out if your shifter moves like 2 inches to the side.
Old Apr 7, 2005 | 08:14 PM
HatchKid12's Avatar
Default Re: Transmission. (88 Crx Si)
I tryed to move it in gear underneath the car...and still nothing
I dont know much about trannys..but I thought if I did this and still nothing the bushings isnt the problem...
But then again im probably wrong about this..
Also, if it is the tranny, what price should I be looking at w/o labor that is
Bump for anymore info...
Old Apr 7, 2005 | 08:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchKid12 &raquo;</TD></TR><TR><TD CLASS="quote">not a cable tranny... </TD></TR></TABLE> Then WTH transmission are you using then?
Old Apr 7, 2005 | 09:51 PM
HatchKid12's Avatar
hrmm some reason the name wont pop in my head...
Instead of a cable its a rod, or like a pole sorta thing,
way to tired to think right now, somereson I wanna say hyrdo tranny but i think thats tottally different..
Old Apr 7, 2005 | 10:03 PM
QuarterMileMaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchKid12 &raquo;</TD></TR><TR><TD CLASS="quote">hrmm some reason the name wont pop in my head...
way to tired to think right now, somereson I wanna say hyrdo tranny but i think thats tottally different..</TD></TR></TABLE>
Oh wow, you really don't know much bout tranny's do ya.... The pole thing you're talking about is the shift linkage. That's not what defines the tranny. What the difference is, is what connects the clutch pedal to the tranny. If it's a cable tranny, you'll have a single cable running from the top of your clutch pedal under the dash, all the way to your tranny (which you probably do). But, on the off chance that you do have a hydro tranny, you'll have a power booster mounted in your engine bay that still runs a shorter cable to your tranny. I would bet that you have a cable tranny. So, on that note, first, find someone you know that knows these things and have them check your adjustments. The clutch pedal and/or lever should have 1/8 to 3/16" play in it.
Old Apr 7, 2005 | 10:05 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchKid12 &raquo;</TD></TR><TR><TD CLASS="quote">not a cable tranny... </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchKid12 &raquo;</TD></TR><TR><TD CLASS="quote">hrmm Instead of a cable its a rod, or like a pole sorta thing,
boosted_hatch_216's Avatar
well if its a zc its probably a cable. and you should adjust your shift linkage and if you need a new tranny itll probably cost you about 150 bucks.
Old Apr 7, 2005 | 10:22 PM
HatchKid12's Avatar
Default Re: Transmission. (boosted_hatch_216)
Hrmm..thanks for help, ill look at it more and what not 2marow
95f22a1
15
Apr 30, 2007 11:40 AM
slow91crxdx
Sep 4, 2006 08:38 PM
Honda Crx
May 29, 2006 07:39 AM
ED8REX
Mar 9, 2006 09:22 AM
CRXEE8
Mar 25, 2004 09:13 AM
