How do you read the code on 89 hf?
When i firt bought my car the check engine light was on. I didn't really care because I'm going to swap in the b16a anyway. But then last sat night the damn Hf died on me at 3 a.m in the morning. I checked and there was no sparks. Oh yeah and it rain the day before my pos died. So how do you check the code? Thanz again.
jason p
jason p
lift up the carpet under the passengers feet,
and take off the ECU 'protector cover' (is this step needed
cant remember if theres a hole there for the LED)
anyhow count the blinking lights..
long pulse=10
short pulse=1
count them up and then use this..
http://hybrid.honda-perf.org/tech/codes.html
courtesy of hybridforum.com
long pulse=10
short pulse=1
You do not need to remove the metal plate. There is a little window in it that allows you to see the led.
weight savings=1hp
Stupid me. I disconnect the negative cable to check if there is any water got into it. ECU was dry. But then I lost all the codes. Darn it. It rain in dallas a couple days before and somehow water got into my crx. I need this thing for another month and then I;m going to start my build up. Also I took the distributor apart, It looks fine.
I'm not familiar with hondas. Any tips? Thanz.
jason p
I'm not familiar with hondas. Any tips? Thanz. jason p
racingcrx
Jan 12, 2008 02:53 PM
Gumbey75
Jan 17, 2005 10:57 AM
chirp2hrd
Jun 16, 2003 06:47 PM
