y8 mini me surging issue
ok i have a surging issue i need fixed.
i have a 90 honda crx si with a y8 mini me swap
D16a block
00 y8 head
stock injectors
00 y8 intake manifold
chipped 90 crx si ECU
vafc
i installed the swap a couple days ago using my stock SI IM but when we first did the swap we forgot to remove the oil jet, and had the timing wrong. So we pulled the head back off and pulled the oil jet and i decided that i wanted to use the y8 intake manifold instead due to the better flowing ability.
we extended all the required wires and hoses,fuel lines and what not.
The car starts right up everytime but thats where the problem starts, the car constantly surges from 1500-2500 no matter what i do.
trouble shooting done already:
swapped MAP sensor
replaced PVC
checked all vacume lines
none of these fixed anything, and the problem is not related to the throttle c able because it does all this without the cable hooked up.
so any suggestions or fixes???
chris
D16a block
00 y8 head
stock injectors
vafc
swapped MAP sensor
replaced PVC
chris
dont the 99-00 manifolds/heads have air injection holes ??
could that be the problem ??
vacuum leaks ??
i remember the y8 IM has more vacuum ports then the a6, so make sure the extra ones are plugged
vacuum leaks ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackCRX »</TD></TR><TR><TD CLASS="quote">dont the 99-00 manifolds/heads have air injection holes ??
Yea, it's called Fuel Injection Air (FIA)
uindaway
13
Nov 1, 2012 01:05 PM
kkim
12
Jul 5, 2005 05:41 PM
92civic_eg
Aug 18, 2004 06:24 PM
