Thinking about converting my car to LS/VTEC what head could i use?
I have a 92 LS im thinking about going LS/Vtec what head should i use?What will i need to get in order to build a LS/VTEC other than the head...If i were to use a civic head what year civic head to use?If i were to use a prelude head would it fit onto my motor?Would i get me HP/TQ because its a bigger head?
Do i have to change my headers when i get vtec or will my headers bolt up the same way?
What 1/4miles sould i expect?I have CAI/H/E/Testpipe...
sounds like you need to do ALOT of researching!!
either stick with a Bseries hybrid motor
or a h22/h23 hybrid motor
For cost: (cheapest way)
get an SI head
and an LS block
u will need to get it (block) machined to accept the bolts of the VTEC head.
http://www.crvtec.com
and do many many more searches on this topic here.
using an LS block and a SI head and your bolt ons will net you 180hp 130ft/lb torque, u will run 14's
there is a GREAT deal in making this engine reliable for high rpms.
u will need to get a good engine builder...u need to add an internal girdle for the block, oil squirters...you WILL need to research this!!
get an SI head
and an LS block
What year SI vtec i can use? Do te SI CRX's have a vtec head? I was thinking of buying the whole vtec motor and then takeing of what i need...But i wanna know wat year SI vtec i could use...Think buying the whole motor is a good idea i can any honda motor for about $500..
hmm, 92' is that year the year when they started obdI?
that im not sure of.
If your car is OBDI then getting an OBD-I, SI head would be easier and cheaper.
any DOHC VTEC head can be used.
here is a little list of what u should get. ALLMOTOR CRAZY!!!
B18b/a block.... $600
B18C1 Head...... $1000 VERY hard to get..
ITR pistons..... $250
ALL new bearings.. $300
Block assembly..... $400
Balance crank...... $200
Head gasket....... $55
Re-tap oil line... $100
Skunk2 intake manifold $320
Type-R throttle body.. $250
Wire harness... $200
Shift linkage... $150
ECU.. GSR.... $300
GS-R tranny... $750
Fuel Regulator + Guage $175
Cam Gears... $250
Type-R cams.. $450
Valve Adjustment.. $50
Motor installation... $800
Intake manifold gasket..$25
Oil/filter.. $15
Axles... $200
Header...4-1 $297
Cold are intake.. $225
New timing belt. $80
New oil pump... $150
New water pump... $150
Dyno Tuning.. $100
270 CC Injectors.. $200 or used prelude..$100
Apex V-AFC controller..$320
6 puck clutch $350
Resurface flywheel.... $30
Total - $8542
prices are from ImportReview.com
ECU.. GSR.... $300
GS-R tranny... $750
Cam Gears... $250
Type-R cams.. $450
Oil/filter.. $15
Axles... $200
Header...4-1 $297
Dyno Tuning.. $100
6 puck clutch $350
Total - $8542
SlowReaction
Northwest (Sales)
May 21, 2007 06:00 PM
