New Engine Buildup, Edelblock Victor X or not?
Old Apr 7, 2005 | 05:58 AM
jwaked's Avatar
Default New Engine Buildup, Edelblock Victor X or not?
Hello People, time to build my new engine for Road Racing. Its a b18C1. The car will have 13:1 Compression, 84mm Pistons, MID kit, Forged Rods, Type R Crank, Race ported head, 70mm TB, JUN III Cams (with retainers and springs), AEM Stand alone computer, 440 Injectors, ATS close gear ratio tranny and 4.92 final drive, Etc.
I have a Skunk II manifold for my B18c head . The Big question is if the Victor X manifold will do better for my purposes. I need torque and as much power as possible. In a few months I will be trying out a b16 Head with a Type R Manifold will make me once again conncerned about the manifold against another Victor X. I heard that they are more for drag racing and not so much for Roar racing.
So should I get the Victor X or not. Thanks
Jay
Old Apr 7, 2005 | 02:07 PM
mRvYbEs's Avatar
Default Re: New Engine Buildup, Edelblock Victor X or not? (jwaked)
Any 2.0 liter high compression motor will definitely need to breathe. In my opinion a Skunk 2 manifold was designed for a 1.8 liter motor and will limit the true potential of the motor. A Victor X manifold will be adequate with your setup because it will complement the 84mm bore, headwork, big cams and high compression. Good luck with your build-up.
Old Apr 7, 2005 | 02:30 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: New Engine Buildup, Edelblock Victor X or not? (MRVYBES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MRVYBES &raquo;</TD></TR><TR><TD CLASS="quote">Any 2.0 liter high compression motor will definitely need to breathe. In my opinion a Skunk 2 manifold was designed for a 1.8 liter motor and will limit the true potential of the motor. A Victor X manifold will be adequate with your setup because it will complement the 84mm bore, headwork, big cams and high compression. Good luck with your build-up.</TD></TR></TABLE> agreed!!! but you cannot beat ITBs if you have the $$$
Old Apr 7, 2005 | 02:36 PM
thevanitygroup's Avatar
Default Re: New Engine Buildup, Edelblock Victor X or not? (HOOKUPS)
AEBS.
2k.civic.si
17
May 12, 2010 08:59 AM
dannyneedshelp
Jul 7, 2009 01:00 AM
jwaked
Apr 7, 2005 09:08 AM
Integ03
18
Nov 9, 2003 09:08 PM
CKDC2
Jun 23, 2002 02:46 PM
