quick question about clear cloat.
Old Apr 7, 2005 | 04:57 AM
XxBeSxX's Avatar
Default quick question about clear cloat.
I own a '92 Accord EX and my clear coat is chipping off, should I just get what i can off and let someone re-coat it, or just get a whole new paint job?
Old Apr 7, 2005 | 09:47 AM
CD7power's Avatar
Default Re: quick question about clear cloat. (XxBeSxX)
is there a lot on clear coat chipping off? i have the same problem but i have a lot of lil spots all over my car. i just wet sanded with 1200grit (i think it was 1200) and waxed it.
Old Apr 7, 2005 | 11:40 AM
XxBeSxX's Avatar
It's on the front panels, right rear panel and both bumpers.
Old Apr 7, 2005 | 12:31 PM
JonnySBeee...'s Avatar
just go get some high grit sandpaper and wetsand with water and Dawn dishsoap, i say use Dawn because all other dishsoaps ahve like lotion in them so ur hands feel softer, well itll **** up ur paint if u use those dishsoaps. after that just give it a wax and your done!
Old Apr 9, 2005 | 06:39 AM
XxBeSxX's Avatar
I'll give it a try...what's the worse that could happen?
Old Apr 10, 2005 | 12:15 AM
sumptimwong's Avatar
Default Re: (XxBeSxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxBeSxX &raquo;</TD></TR><TR><TD CLASS="quote">I'll give it a try...what's the worse that could happen?</TD></TR></TABLE>
if your clear coat is gone, then you're sanding paint -_-.....
before u try sanding your car, why dont you try an abrasive polish instead? i like meguiar's scratchX. if that doesnt work, slowly move up to the more abrasive techniques, eg wet sanding. and whenever u find something that works, be sure to wax that spot after u work on it. don't use the rattle can clear coats, they look like crap unless u take the whole panel off and coat the whole panel. even then, it takes a lot of practice and experience to get it right. gl
JJ's civic
Paint and Body
May 6, 2007 06:59 PM
lude-tec
Jul 29, 2006 07:48 PM
4ghatch
Jun 27, 2005 08:55 PM
4thgenlude
May 14, 2004 06:48 PM
