Chassis Electrical Problems??????
Old Apr 7, 2005 | 03:45 AM
ORcivicsi's Avatar
Default Chassis Electrical Problems??????
On my 00 si. My radiator fan does not turn on? I have not checked the switch yet. I will this weekend. But i wanted to know if this problem has any thing to do with the removal of my Air Conditioning? I know that it left a bunch of un connected wires when i removed it. Has anyone else had this problem?
Also my turn signal on the front driver side doesnt work any more. The parking/night (orange light) works for the same bulb but it doesnt blink for the turn signal. I removed my windshield washer pump (dont ask why, it has to do with my cf hood).I have a feeling this has to do with the windshield washer pump. Does any one know if the unused connections have to do with my turn signal?
Help Please?
Pics for thread attention!
Old Apr 7, 2005 | 04:10 AM
JimBlake's Avatar
Default Re: Chassis Electrical Problems?????? (ORcivicsi)
Usually the radiator fan circuit is connected into the AC circuit. Did you try to remove all the AC wiring or just the mechanical components? You'd have to look at the wiring drawings & put back the parts that are related to the fans.
Parking/turn bulbs have 2 filaments. Sounds like one of them is burned out.
Old Apr 7, 2005 | 06:22 AM
ORcivicsi's Avatar
Default Re: Chassis Electrical Problems?????? (JimBlake)
I just removed the mechanical components. So i have to find the the wires that go from the AC fan to the radiator fan.
And if i just replace the turn signal bulb it should work again.
Old Apr 7, 2005 | 08:12 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ORcivicsi &raquo;</TD></TR><TR><TD CLASS="quote">I just removed the mechanical components. So i have to find the the wires that go from the AC fan to the radiator fan.</TD></TR></TABLE>Usually the 2 fan relays are wired together in a way that allows the AC & the fan switch to work together to control the fans. Gotta have a wiring drawing for the proper year, which I don't own... Since you only removed the mechanical components, I'm now guessing it's not related to you taking AC out of the car.
I'm pretty sure the fan switch will be in your thermostat housing. Unplug it & jumper the wires together with a paper clip. Key on, that should make the fans run. If it DOES, then you need a new fan switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ORcivicsi &raquo;</TD></TR><TR><TD CLASS="quote">And if i just replace the turn signal bulb it should work again. </TD></TR></TABLE>That's the cheap/easy thing to try first. If that doesn't work then you can worry about wiring.
Old Apr 7, 2005 | 01:57 PM
ORcivicsi's Avatar
Thanks!
giovannie23
Feb 28, 2013 12:17 AM
stuie08
Oct 22, 2007 12:54 PM
hassan21
Aug 30, 2007 12:37 PM
frog169
May 19, 2007 01:19 PM
ORcivicsi
Apr 7, 2005 07:52 AM
