what is the diiference 88-89 to 90-91 headlights
Old Apr 6, 2005 | 10:21 PM
zerogravitycrx's Avatar
Default what is the diiference 88-89 to 90-91 headlights
what is the diiference 88-89 to 90-91 headlights?
Old Apr 6, 2005 | 10:50 PM
Zaakro's Avatar
Default Re: what is the diiference 88-89 to 90-91 headlights (zerogravitycrx)
nothing really 88-89 can work on 90-91s and vise versa, the only differences is that on the 90-91 the corners screw into the lights and the 88-89 the corners screw into the fenders...... correct me if im wrong
Old Apr 6, 2005 | 11:17 PM
Default Re: what is the diiference 88-89 to 90-91 headlights (Zaakro)
your right on the signal lights year to year!
how about can crx headlights work on 1988-1991 hb or 4 door civic's?
Old Apr 6, 2005 | 11:25 PM
Civic138's Avatar
also 91's and i think 90's has a vent so water wont build up in them,while 88-89's dont
Old Apr 6, 2005 | 11:30 PM
2nxcrx's Avatar
Correct me if I'm wrong but to switch back and forth and retain your corners you need to switch out the "baskets" or the housing frames around them where they bolt to your car from your year to the new ones. This is pretty simple to do after you do it a couple times. I've switched over a 90 sedan to a 88 crx and it went pretty smooth.
Old Apr 6, 2005 | 11:50 PM
Nerologic's Avatar
Default Re: (2nxcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerogravitycrx &raquo;</TD></TR><TR><TD CLASS="quote">your right on the signal lights year to year!
how about can crx headlights work on 1988-1991 hb or 4 door civic's? </TD></TR></TABLE>
dont worry they are the same too...
Old Apr 8, 2005 | 11:42 AM
Vrooomski's Avatar
Bump
Old Apr 8, 2005 | 11:53 AM
Twilight's Avatar
Default Re: (Rich_eFsquaD)
The European 88-89 lights are slightly diffrent than European 90-91 model lights. 88-89 light does have separate low and high beam bulbs (h4 low, and H2 high). And the 90-91 lights does have same bulb (h4) to high, and low beam.
Old Apr 8, 2005 | 03:34 PM
Nerologic's Avatar
Default Re: (Twilight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilight &raquo;</TD></TR><TR><TD CLASS="quote">The European 88-89 lights are slightly diffrent than European 90-91 model lights. 88-89 light does have separate low and high beam bulbs (h4 low, and H2 high). And the 90-91 lights does have same bulb (h4) to high, and low beam.</TD></TR></TABLE>
yup they are single bulb just like the SiR headlamps
ryyo
Dec 25, 2007 08:39 PM
90 JDM EF8
May 20, 2006 10:30 AM
B.S._TURBO
Nov 15, 2004 02:50 PM
24hourflipness
Apr 16, 2003 01:43 PM
ruiner17
Feb 16, 2003 03:29 PM
