battery light turns on???
Old Apr 6, 2005 | 09:55 PM
drewcandraw's Avatar
Default battery light turns on???
I was wondering what could be triggering my battery light to turn on when im driving..it just started happening and so i thought a new battery would solve the problem yet the light keeps turning on...I experienced it today and it happens when i dont release the clutch quick enough on 2nd gear and it just goes on sometimes too.What is the problem???? I hope something is not really fucked up because thats my only car???
Also, my windshield wiper motor suddenly out of the blue died on me...It just makes a clonk noise when i try to turn it on...How do i rectify this situation also???
thanks....hopefully i didnt ask some stupid questions
Old Apr 6, 2005 | 09:58 PM
Gumbey75's Avatar
Default Re: battery light turns on??? (drewcandraw)
alternator get that checked at your local parts store most likely its going out
Old Apr 6, 2005 | 10:06 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: battery light turns on??? (Gumbey75)
the battery light tells u that the alt. is not charging tha battery; thus ur running the car on the battery(not good). get the alt. checked at autozone. there free
as for the wiper, the clunking says that the motor is working. most likly the arm conecting the wipers to the motor has fallen off. remove the plastic between the hood and the windsheld and u should have acsess.
Old Apr 8, 2005 | 11:39 AM
Vrooomski's Avatar
bump
Old Apr 8, 2005 | 07:13 PM
Default Re: (Rich_eFsquaD)
could the alternator be the cause that my windshield wiper is not working. After reading chiltons, i found out that the alternator is the item that provides power to the engine and feeds electrical power to the other systems in the car. Do you think i can replace the alternator on my own or should i get a mechanic to do it for me???give ur opinons so i can fix my car this weekend
Old Apr 8, 2005 | 10:13 PM
riceisnicenv's Avatar
Default Re: (drewcandraw)
if you know about simple mechanics you should be able to do it. you remove the belt, the bolts holding it on then twist, push, pull, pray, and persevere that thing right out of the engine bay. if you have a chiltons just look up the directions about alternator removal. if you don't feel comfortable with a ratchet then don't do it...
Old Apr 13, 2005 | 07:12 PM
golfcart's Avatar
Could be a few things...alternator,bad motor for wipers(believe me sometimes these things happen in bundles),or a bad sensor. Another indicator of a weakening alternator is your lights will begin to ocassionally dim or you'' notice a decrease in power from other places(Ssuchas a wiper motor). I'd get it checked soon though. Because once that goes, your car don't go till you get a knew one. Because soon it will get so weak the battery will not be able to recharge.
Old Apr 13, 2005 | 08:27 PM
Exempt's Avatar
Have u installed an aftermarket intake on it? I ask because when i first installed mine, the batt light would come on... Turned out the intake was grounding out on the battery terminal... Even tho I added a bit of electrical tape for just that reason... It ate a hole in my intake too from it... So I had to rig something up to where it wouldnt touch the terminal at all...
Old Apr 14, 2005 | 07:17 AM
Mr_Si-R's Avatar
Default Re: (Exempt)
move the batt to the back
Old Apr 14, 2005 | 03:19 PM
Default Re: (Mr_Si-R)
yup i have an aftermarket intake but that was not the problem..i went to kragen and asked for the free alternator test and that was the problem..it was not charging the battery so i got that changed...but the windshield wiper doesnt work...
can someone tell me approx. how long will it take to fix the windshield motor and how much is a used motor worth???im buying a working used motor from a friends parts car. also i am trying to buy a good condition passenger mirror with everything adn would liek to know how much is it worth??? thanks for all the help
KiTTyOnRoiDs
Acura TL, RL & ZDX
Jun 11, 2015 12:53 PM
idontknowwhatimdoing
Jul 31, 2007 06:01 PM
uneek4dr
Mar 26, 2006 11:24 AM
xsellxoutx
Apr 25, 2004 01:14 AM
