Driving untuned..
b16a2
p&p head
3 angle valve job
AEBS intake manifold
AEM cia
AEM fuel rail
4-1 header
HKS cat back
test pipe
AEM cam gears/pully
Gude stage 2 cams
B&M FPR
62mm TB
I just got rid of my JDM p30 and vafc,
ive got a chipped p28 / hondata s200 from a fellow HT memeber
it was tuned for 195whp, forgot the full setup.. anyways..
With it, My car runs.. not good, but it moves
how critical can it be driving it around for about a month
Ive put about 75 miles on it like this, never took it about 4k
_________
4-16 - 05 EDIT
Alright still driving untuned, been like a month..
I got a CEL and i checked it and it came up..
43: Fuel supply system
ideas?
Modified by athoughts at 6:24 PM 4/16/2005
p&p head
3 angle valve job
AEM cia
AEM fuel rail
4-1 header
HKS cat back
test pipe
AEM cam gears/pully
Gude stage 2 cams
B&M FPR
62mm TB
_________
4-16 - 05 EDIT
ideas?
not good as in.. it runs pretty stock and bogs
i am getting it tuned, in the end of the month
but until then im wondering if its safe to drive it around or just drive another car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Drive another car...please.</TD></TR></TABLE>
ya im pretty sure the AFis way off
ill try to borrow a stock one for awhile
__
what damage could this cause, i did drive 1 day on it, about 75 miles, never higher than 4000rpm
__
i dont think you'll get any serious engine damage. just dont rev high! maybe 4t rpm max. im pretty sure the mapping of that ROM is waaay rich that u need. just expect some shittty gas mileage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts »</TD></TR><TR><TD CLASS="quote">never higher than 4000rpm</TD></TR></TABLE>
alright then, well im off to work in my car, cause my others are out of gas...
we will see what happens i guess, about to put another 25 miles on it
This is ridiculous. How many of us have driven untuned for long periods of time when we first got into swaps? Im sure like 90%. Check your plugs, make sure they are a litle grayish brown or close, if you have a AFPR and gauge keep it set to 50psi with the line off (40 with it on) to be safe. Make sure your cam gears are at 0 and also make sure your timing is not advanced or retatreded, just stock. Other than that, get tuned when you get a chance but I would definatly not tell you to stop driving the car unless your seeing some leaness on the plugs, pinging, or feeling problems in the power band.
I'm using a JDM GSR motor with CTR Pistons, S2S2 cams. I have the stock ecu right now running it, and all I can say its alright. I dont get on it, or **** above 4500 rpms, most time its around 4k. I've got about 400 miles on it so far, and it has terrible gas mileage, but you'll be fine. Its gonna be another couple weeks before I can get mine tuned, but I'm not having any major issues, yet.
its not the problem running a stock ECU and saying im untuned..
the p28 and hondata i have in, i got from thsi guy, and its tuned and setup for his SETUP, far from mine..
And yes, i did set my cam gears at 0 and my timing stock, ive put everything to stock..
how are your plugs though? my point is, if you running a little rich then its fine. If his setup was running lean as all helll and now has you running lean as all hell then your going to want a tune ASAP. If he was tuned at 195HP he was most likley consuming more fuel than you with the lesser HP which means your likely on the rich side. If the plugs look good, you can drive without tuning until you get the money. Just please dont go pushing it
Running rich can wash out the rings , Running lean well you know what happens then. At least put a wideband on it to make sure your not overly rich or overly lean. I wouldnt drive it untuned or on a stock ecu unless it was a very mild setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER »</TD></TR><TR><TD CLASS="quote">Running rich can wash out the rings , Running lean well you know what happens then. At least put a wideband on it to make sure your not overly rich or overly lean. I wouldnt drive it untuned or on a stock ecu unless it was a very mild setup</TD></TR></TABLE>
He's right, though running a tad rich isnt so bad as running lean, if you are running rich you can wash out the piston rings. Your motor and setup are not in the neighborhood of `195whp. Sooo, Your prolly getting too much fuel. You could try to turn down the pressure a tad.
Best advice would be not to drive it much, especially if its running rich enough to bog it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 »</TD></TR><TR><TD CLASS="quote">
Best advice would be not to drive it much, especially if its running rich enough to bog it out.</TD></TR></TABLE>
If it's rich enough to foul the plugs, PARK IT. Mine went that far and I got the dreaded cylinder wash. Now the car needs to have a short block rebuild even though that's not exactly in the budget
yeah ive been driving it around, i checked my plugs, they look good and my fpr is set on 40, everything should be alright
getting it tuned next week
my car is also running untuned, very rich....where can i get it tune (i live in Seattle) and what kind of tuning does it has to go through????? Does it need to be dyno or can i just get a aftermarket fuel regulator and a vafc and go to any shop to get it tune.
Modified by GangStaBear at 1:23 AM 4/12/2005
yup been like 3 weeks now, still driving untuned... i officially get HORRIBLE gas milage, spark plugs still seem good..
imma keep on waitin till i can get tuned.. people lag!
