engine building question
Old Apr 6, 2005 | 08:26 PM
W C L's Avatar
Default engine building question
we got a gsr shortblock back at the shop that local machinist assembeld it spun some bearings and what not...
the specs on the motor are as follows crank was ground down .25mm and fitted with propper size rod and main bearings, but the thrust washers where standard size, im not understanding y they would have that standard size thrust in it instead of the .25mm (thicker) thrust????
witha crank being ground the thrust area would be ground down also correct, in which would need the .25mm thrust?
could this be part of the motor failure????
Old Apr 6, 2005 | 08:49 PM
Jim Truett's Avatar
Default Re: engine building question (Big Will)
You do not grind the thrust faces on the crank, only the journal diameters. I personally would not have ground a Nitrided crank anyway. I bet the failure was caused by a lubrication or clearance problem.
Old Apr 6, 2005 | 10:12 PM
W C L's Avatar
Default Re: engine building question (Jim Truett)
the crank was scuffed up and needed to be ground down (journals)... yes i know that the journals are the parts ground down... i was wondering cause the bearings are marked .25mm and the thurst was marked std, thats why i ask...
thanks though
Old Apr 7, 2005 | 07:34 AM
quickcarl's Avatar
It could also be a journal alignment issue.
Old Apr 7, 2005 | 08:41 AM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Will &raquo;</TD></TR><TR><TD CLASS="quote">im not understanding y they would have that standard size thrust in it instead of the .25mm (thicker) thrust</TD></TR></TABLE>
Because there's only one size thrust bearing. If they ground the thrust surfaces there's trouble, as people have noted above.
Old Apr 7, 2005 | 09:23 AM
quickcarl's Avatar
Default Re: engine building question (drdisco69)
The thrust surfaces of the crank work side to side if you will, not by a diameter as a journal does. Unless these "side" surfaces were damaged, they wouldn't be ground wider when the journal diameters were ground.
Old Apr 7, 2005 | 02:51 PM
W C L's Avatar
thanks for the input i know what casued the spun bearings... the thrust wahser is someting i have always wondered about, it was just a question for my noggin.......
Mr Tickle
Dec 8, 2008 09:25 AM
94-integra-ls
Feb 7, 2006 07:23 PM
hondaeg8
Mar 22, 2005 12:50 AM
SHhh__VTEC
Jun 2, 2004 11:19 PM
bigTom
Mar 19, 2002 06:18 PM
