valvetrain upgrade! What else?
I have a 1st gen b16 and I am haveing a shop install my CTR cams and ITR valve springs and retainers WITHOUT removeing the head. I am also going to replace the LMAs with h22 LMAs using the washer trick. Is there anything else I should have the shop do While there in there?
thanks
Matt
thanks
Matt
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by insomniac791 »</TD></TR><TR><TD CLASS="quote">well ive heard that the LMAs in the 1st gen b16 heads are weak and wear out quickly with bigger cams? Do you think that I shouldn't bother worry about them?</TD></TR></TABLE>
no....
no....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic! »</TD></TR><TR><TD CLASS="quote">
no....</TD></TR></TABLE>
so i don't need to replace them? Or no i do need to replace them?
^ its cheap insurance... I say do it, so many people skip the LMA's but with alot of these heads that are used, you have no idea how many miles are on them. I always recommend doing it to heads with unknown milage or mild tick if they are out and easily accessable.
well the itr LMAs are like 30 bucks a piece. prelude LMAs work just as good but they are a sligh bit shorter that the ITR so you get a washer and put it in then the lma on top and there you go.
here is a whole thread about it
https://honda-tech.com/zerothread?id=566420
