New ef owner??
Old Apr 6, 2005 | 05:54 PM
vadersi's Avatar
Default New ef owner??
I just picked up a 91 hb with no rust and a ls swap for 1500..I plan on putting my built ls motor in it just ordered the hydro conversion .. what clusters will work... all 88-91 civic and crx clusterss. will they all plug in.. and what brake upgrades do you guys recommend.. I search for both. I know egs and ek like the back of my hand but ef's I don'tlnow... is there a camber kit like the skunk2 or just the adjustable joints..
thanks
Old Apr 6, 2005 | 06:10 PM
kulangot's Avatar
Default Re: New ef owner?? (vadersi)
90 -91 cluster's will work not 88-89, da integ brakes will work all the way around...
check ebay for camber kits
Old Apr 6, 2005 | 06:20 PM
kaoss_11's Avatar
B A N N E D
welcome to the club
Old Apr 6, 2005 | 06:24 PM
vadersi's Avatar
Default Re: New ef owner?? (sirq2u)
is it the same as the egs will I have to do the knuckles to go bigger brakes.or what ... what can I do if I don't wantto change knuckles.. adn the clusters are the same in the 90-91 rex and civic right... I wish I could find a good camber kit.. I might jsut go fast brakes .. like my other two civics.
Old Apr 6, 2005 | 07:38 PM
bagpipe goatee's Avatar
there is a thread on here where you can use caliper brackets and different calipers to run 10.3 inch brakes. i don't remember the url, so i guess you have to search.
the da knuckles mess with your camber curve a little,
oh and there are no real adjustable upper control arms that i've seen yet, but there's this one guy that took them from an eg ( i think) and cut and welded them onto our upper control arms.
myed9crx
Aug 17, 2011 04:07 AM
uberhaulin
Suspension & Brakes
Feb 27, 2007 04:38 PM
Mac
Jul 26, 2006 04:08 PM
Wink1100
27
Oct 27, 2005 08:56 AM
crx91-sir1
16
Jan 14, 2003 08:29 AM
