What cam should i use?
Old Apr 6, 2005 | 05:19 PM
drowzysleeper's Avatar
Default What cam should i use?
i got a d16y8 soon to be running 12 to 1 comp. was wondering what kind of cam to use? was also wondering if i needed to upgrade valvetrain, if so what should i get? these are probably dumb questions but im new to modding and didnt have any luck with the search. thanks
Old Apr 6, 2005 | 05:29 PM
Default Re: What cam should i use? (drowzysleeper)
bump for help
Old Apr 6, 2005 | 08:04 PM
UncleD's Avatar
I believe, and if you can find it, I believe Jun makes a camshaft for your motor. There was a SOHC runnin around Salem Oregon with one and it was MEAN. You will for sure hafta upgrade the valvetrain, but if you can find the Jun cam, DO IT. Gude is big on the singles, but I have never been impressed with there product, Skun 2 also makes a camshaft for you.....good luck man
Old Apr 7, 2005 | 02:09 PM
Default Re: What cam should i use? (clean rice)
thanks, what stage would you recomend?
Old Apr 7, 2005 | 02:24 PM
after work bump
Old Apr 7, 2005 | 09:02 PM
Evo-man@20psi's Avatar
Go twin cam
Old Apr 7, 2005 | 10:56 PM
UncleD's Avatar
Default Re: What cam should i use? (Blue00vtecsi)
I believe Jun only makes one "stage" of cam for the SOHC. If you were to do the Skunk, I would go with the stage 2, maybe stage 3 if you had headwork combined with a free flowing intake manifold and a good header, maybe a SMS or something like that. Just make sure you don't do the S2 valvetrain.....they are suppose to have there new "pro" line out, but they have not been tested yet, and the old S2 valvetrain was ****. Good luck man
Old Apr 8, 2005 | 01:34 PM
other people are saying im gonna be running 13 to 1 comp do you think i will be able to run pump gas? also what do you think of zex cams?
Old Apr 8, 2005 | 02:18 PM
Rocket's Avatar
Y8 cam.
Old Apr 8, 2005 | 04:37 PM
Default Re: What cam should i use? (Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Y8 cam.</TD></TR></TABLE>
what? are you saying y8 cams are better?
Old Apr 8, 2005 | 04:40 PM
Rocket's Avatar
From testing I've seen they are prettty good compared to other aftermarket offerings.
Old Apr 8, 2005 | 06:11 PM
could they handle the compression
Old Apr 8, 2005 | 07:43 PM
UncleD's Avatar
If Randy reccommends something, go by it....swear by it.
xkrazyxjbrkerx75
Nov 4, 2009 10:48 PM
gsrturbo-ek
Northeast (Sales)
Jan 3, 2009 07:56 PM
an2ny888
May 21, 2005 08:58 PM
zseeanz
Jun 24, 2003 09:38 PM
