Question for all Clifford Matrix owners
I bought a refurbished alarm matrix alaram and i was going to install remote start for my del sol yesterday except that we needed the installation guide which came from the retail box to tell us what wires were what on the remote start module. I have a wiring diagrm this is the only thing i need.
I dont need the owners manual its the other manual that came with the package which was the installation manual as if u were to install it urself which is not on the clifford or directed website.
Which Clifford Matrix alarm is it? Matrix 1,2,3....RS 2.5, RSX 3.5??? If I cant send it to you in PDF form, I can list what each wires purpose is.
Matrix rs 3.5 the module that I need to know about is the extreme capacity relay stellite (XCRS 500m). What i need to know about it is what each wires function does and goes to, to and from the module. One side has two fuses and more thick wires than the other side which only has thin wires .
Red Wires W/ 30 amp fuses : 12V Constant
Purple Wire: Starter Side of the Starter wire
Green Wire: Key side of the starter wire
Orange Wire: Accessory Output (No need to use this one on your car)
Pink/White Wire: 2nd Ignition Output (Not needed if your car does not have a 2nd ignition. Most hondas dont require it either)
Pink: Ignition Wire
The 4 thin wire plug is not needed or required in most installations. Just connect the ribbon to the brain, make your connections with the heavy gauge wire, and BAM!
Pink: Ignition Wire
erikiksaz1
Audio / Security / Video
Mar 16, 2004 04:08 PM
dvp95
Aug 23, 2002 04:39 PM
