Type R ECU questions
Will a USDM OBD1 P30 from my B16A3 run a 2001 JDM Type R? If not I have a JDM aftermarket Name Brand P30 ECU that runs on the rich side, will that one work? I also have a Vafc II. Do you guys think I can run my Type R with this equippment, or should I look into something else? Also since it is a jdm motor the harness will not work without some modification, can I just use my B16 motor harness and rewire the distributor and injectors? Thanks
black2001gsr
Jan 23, 2003 08:53 PM
