cams specs? post cam specs here
anyone got cam specs on 99b16 and 95 gsr cams
here are the cam specs for ctr and itr
Integra Type-R
Int-240 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Valve Springs to be used: Stock B16A/GSR if using stock 8200 re-limit. Integra Type-R if using rev limit over 8200rpms. Mugen Valve Springs can also be used.
Description: These are great, reliable cams for the money. They will eliminate that low end sluggishness and give you great power gains all the way through your power band!.
Civic Type-R
Int-243 dur. / 11.5mm lift
Integra Type-R
Civic Type-R
surefeelsgood
Oct 18, 2010 07:22 AM
catfishracer4748
Oct 26, 2009 09:28 PM
